Old 08-30-2016, 08:57 AM   #1
FlatheadK
FlatheadK's Avatar
Default 1932 ford pickup GVWR.
I'm looking for 1932 pickup gross vehicle weight rating chart.
Please contact me if you have.
I need it immediately.
Thank you.
email:[email protected]
FlatheadK is offline   Reply With Quote
Old 08-30-2016, 09:58 AM   #2
Krylon32
Default Re: 1932 ford pickup GVWR.
Looked at the title for my 32 pickup and it does not have gvw listed?
Krylon32 is offline   Reply With Quote
Old 08-30-2016, 10:16 AM   #3
Seth Swoboda
Seth Swoboda's Avatar
2579 lbs
Old 08-31-2016, 08:18 AM   #4
Capn John
Capn John's Avatar
go here:
http://www.fordbarn.com/forum/showthread.php?t=142969
see the image toward the end of the discussion with the vehicle weights
Capn John is offline   Reply With Quote
Old 01-15-2021, 12:32 PM   #5
'32FordNut
'32FordNut's Avatar
I'm trying to register my 1933 Ford P/U Model B in Cali. Would you guys agree that the '33 is probably the same GVWR as the 1932 that is in the Service Bulletin that was listed in this thread. I'm putting 2500 Lbs. Does that sound reasonable? Thanks for the help
'32FordNut is offline   Reply With Quote
Old 01-15-2021, 01:47 PM   #6
DavidG
DavidG's Avatar
Ford did not publish a GVWR for '32 commercial vehicles, but if they did it sure as hell would not have been 2,579 pounds for the pickup given that the Ford-published shipping weight (no coolant or gasoline or spare tire and tube) of the B closed cab version was 2,366 pounds and that of the V8 version was 2,496 pounds. They may not have been heavyweight hauling champions, but they could indeed carry more than 213 or 83 pounds, respectively, in the form of driver, passenger, coolant, gasoline, spare tire and tube, and bed load.
Old 01-15-2021, 01:57 PM   #7
Bob C
Here is a link to the CA weight exemption.
https://www.lawserver.com/law/state/...icle_code_9401
Old 01-15-2021, 02:57 PM   #8
TJ
TJ's Avatar
See BobC's post. No need for GVW when 36 and older. Your DMV person should know that as in the vehicle code. Although I should not make assumptions on what Cal DMV knows or should know.
Old 01-15-2021, 06:40 PM   #9
rotorwrench
rotorwrench's Avatar
What ever it could carry with the rear tired still holding it up and the front tires still on the ground. Folks weren't real interested in stuff like that unless they were heavy haulers and those guys went with a BB type trucks with either single or dual rear wheels and helper springs if necessary.
They likely could carry around 1000 lbs of load with the light commercial pickup without too much problems. I imagine the Ford sales force could tell a customer how much load weight they could carry safely.
Old 01-15-2021, 07:14 PM   #10
51504bat
51504bat's Avatar
32FordNut:
Your p/u is exempt from weight fees in CA as noted above. Even if it wasn't the DMV would need a certified weight slip to determine weight fees not the manufacturers GVW rating. When I registered my '40 1/2 ton that I bought out of state I had to produce a weight slip from a certified scale (along with some other stuff).
Old 01-15-2021, 07:20 PM   #11
Krylon32
I have a Nebraska 32 pu title that lists it as 1/4 ton. I'm assuming that's because it was only rated to haul 500 lbs comfortably? I'll bet you'd be surprised of some of the loads stuffed into that box.
Old 01-31-2021, 10:21 PM   #12
'32FordNut
'32FordNut's Avatar
Sorry for the late delay in answering. I thought I would get an email or text when I received an answer, I guess not. A friend is doing the VIN Verification for me and I was trying to get as much info for him as possible since he doesn't do these. Thank you so much BobC and 5150, I printed out the exemption so we can attach that for DMV. Thanks again for your responses.
