Old 10-03-2020, 12:08 PM   #1
carguybill
carguybill's Avatar
Default Problem Removing Steering Wheel
I need to remove the steering wheel on my '34 to replace the bushing in the steering column with an upgrade bearing.
Before I can remove the wheel I need to remove the lights and horn button assembly and in order to remove that I need to remove the tab at the bottom of the control rod. See photo.
My problem is that I have not been able to remove the tab. I have tried prying on it but without much success and I'm afraid I will damage the cup that surrounds the tab.
I will appreciate any suggestions and comments. Thank you.
carguybill is offline   Reply With Quote
Old 10-03-2020, 12:19 PM   #2
TJ
TJ's Avatar
Default Re: Problem Removing Steering Wheel
Are you referring to the fork on the bottom of the rod after you have removed the light switch?
Old 10-03-2020, 01:10 PM   #3
DavidG
DavidG's Avatar
Assuming you are referring to the C-shaped clip that retains the two-prong switch actuator, you might consider sacrificing a cheap screwdriver wide enough to capture the ends of the C and grind or file the center of the screwdriver blade to create a very limited use tool for this purpose.
Old 10-03-2020, 01:16 PM   #4
Terry,OH
Terry,OH's Avatar
Near the bottom of the horn rod there is a recess in the recess is a C-clip. The C-clip holds the light switch spider and spring in place. The C-clip has to be removed usually by compressing the spring a little. All the parts have modern replacements, except the rod itself. At the very end of the rod is a plastic insulating insert be careful not to damage the plastic. Once the C-clip is removed the spider and spring will slide off the horn rod.
Old 10-03-2020, 03:14 PM   #5
Kerk
Be VERY careful to NOT BEND the light rod AT ALL as if has a bend turning the steering wheel will turn the lights on and of !!! kerk
Kerk is offline   Reply With Quote
Old 10-03-2020, 03:21 PM   #6
carguybill
carguybill's Avatar
OK, that makes sence. Thank you.
Do I need someone at the steering wheel to keep the light control tight against the steering wheel while I push the light switch spider back to expose the C-clip? Will I then be able to remove the C-clip with needle nose pliers?
Old 10-03-2020, 04:09 PM   #7
Kens 36
Kens 36's Avatar
I use a heavy yardstick under the steering wheel and over the horn button to keep the rod pushed down. Maybe this will help you.
Ken
https://www.nirgv8.org
Kens 36 is online now   Reply With Quote
Old 10-03-2020, 05:45 PM   #8
JSeery
JSeery's Avatar
Might want to be sure the battery is disconnected during all of this!
Old 10-04-2020, 08:23 AM   #9
1931 flamingo
1931 flamingo's Avatar
Also be careful as that seem to fly around either during removal or installation like the small carb clips ("jesus" clips).
Paul in CT
Old 10-04-2020, 10:25 AM   #10
Bob C
This picture may help.
Old 10-04-2020, 11:25 AM   #11
deuce lover
deuce lover's Avatar
I Just push up on the pronged tip in the pic above post by BobC and the horse shoe clips comes out pretty easy .
Old 10-04-2020, 11:48 AM   #12
glennpm
glennpm's Avatar
Yes, "the horse shoe clips comes out pretty easy", getting it back in is the fun part ...
glennpm is online now   Reply With Quote
Old 10-04-2020, 12:28 PM   #13
DavidG
DavidG's Avatar
Kens 36's suggestion to use a yard stick across the horn button and underneath the perimeter of the steering wheel is a big help for either removal or installation of the C clip, as is Bob C's helpful illustration of the component parts including the spring that has to be compressed to remove the pressure holding the clip in place.
Old 10-11-2020, 02:43 PM   #14
carguybill
carguybill's Avatar
Thanks to everyone who shared their experience and knowledge. With your guidance and another pair of hands from my son I finally got the light control shaft removed.
Now my problem is removing the steering wheel itself. I have a decent selection of pullers but I'm concerned that standard pullers will damage the back side of my original '34 steering wheel.
So, here i am again asking for help for ways to pull the steering wheel off of the steering shaft.
Old 10-11-2020, 03:12 PM   #15
glennpm
glennpm's Avatar
You can drill and tap the steering wheel hub, I suggest 5/16"-24, and then use one of these pullers. They're available at any auto parts store and reasonable.
Old 10-11-2020, 07:49 PM   #16
Zeke3
Zeke3's Avatar
I like the idea to use a bearing separator under the steering wheel if you don't have the K.R. Wilson puller.
Zeke3 is offline   Reply With Quote
Old 01-08-2021, 06:18 AM   #17
mercman from oz
mercman from oz's Avatar
To remove the steering wheel from your 1934 Ford with ease, you need one of these dedicated Ford Steering Wheel Pullers.
Old 01-08-2021, 06:58 AM   #18
deuce lover
What glennpm said works.I have a '33 and did that - now no more issues to remove the steering wheel.
Old 01-23-2021, 03:31 PM   #19
Gregger Rod & Custom
Gregger Rod & Custom's Avatar
Thanks Glenpm,
that is the solution I needed,
Gregger
When you turn on your car, does it return the favour?
Gregger Rod & Custom is offline   Reply With Quote
Old 01-23-2021, 03:43 PM   #20
glennpm
glennpm's Avatar
Great its pretty easy, doesn't show and the tool is cheap too. Glad it worked out for you Greg!
Glenn
