Old 01-02-2021, 12:30 PM   #1
woodrow
Default wiper motor question
I have a 1955 Ford Fairlane Victoria and would like to replace the vacuum wiper motor with an electric motor, 12 volt. Will a '56 wiper motor work? Is the location of the original radio a problem? Suggestions on source and price please. Thanks
woodrow is offline   Reply With Quote
Old 01-02-2021, 04:21 PM   #2
steve fritz
Default Re: wiper motor question
I have used the NEWPORT ENGINEERING wiper conversion for several of my mid 50's Fords over the past 20 years. They are a well built unit and have worked perfectly in my cars. ( 57 Ranchero , 57 T bird , recently 55 Ford wagon ). You can just google NEWPORT EBGINEERING and order directly from them. Electric vrs vacuum is the way to go.
steve fritz is offline   Reply With Quote
Old 01-02-2021, 06:14 PM   #3
woodrow
Thanks, I will get with them on Monday. I appreciate your suggestion.
Old 01-03-2021, 09:06 AM   #4
Gene F
Gene F's Avatar
Mine is Newport also, bought through Concourse. I love mine. Except the switch acts kind funky. Best insurance against rain I guess because since installing it I have never needed the wipers.
57 Ford
Old 01-03-2021, 09:50 AM   #5
51504bat
51504bat's Avatar
I put a Newport in my '54 Ranch Wagon. Bought it directly from Newport. Good people to deal with. Fairly easy install with good directions but I did have the radio and speaker grill out which made things easier. In all the threads I've read about wipers I've never read a negative post about Newport's.
Old 01-04-2021, 09:20 AM   #6
bobss396
bobss396's Avatar
I have one in my car too. The price is the same no matter who sells them.
bobss396 is offline   Reply With Quote
Old 01-05-2021, 11:26 AM   #7
51504bat
51504bat's Avatar
You can find Newport Engineering units on the auction site that includes free shipping. There are 2 different units listed for 1955 Fords, one with the stock radio and another without.
Old 01-05-2021, 05:34 PM   #8
frank long island
frank long island's Avatar
i had one in my 55 merc wagon and my 65 ranchero i went for the intermittent switch they work great although you will need the switch extension if you go that route
frank long island is offline   Reply With Quote
Old 01-05-2021, 08:56 PM   #9
paul2748
paul2748's Avatar
I got Newport wipers in three cars. One I installed with the dash installed (54 Ford) and don't remember any particular problem. Need to take the seat out for more room to work. The other two I had the dash out so it was easy.
All three units work very well.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 01-09-2021, 06:09 PM   #10
gtrhotrod
gtrhotrod's Avatar
Newport Engineering units work great.
gtrhotrod is offline   Reply With Quote
Old 01-11-2021, 11:17 PM   #11
reman
So....no one knows if a 56 wiper motor will fit into a 55? If the 55 has been converted to 12 volts?
reman is offline   Reply With Quote
Old 01-12-2021, 12:26 AM   #12
dmsfrr
dmsfrr's Avatar
I suspect the '55 and '56 full-sized cars originally used vacuum powered wiper motors, could be wrong, and I don't have a parts book to see if they used different wiper motors for the two years.
The full-sized cars had a dashboard redesign from '55 to '56 and IIRC the radio is a different design in those two years and may have interfered. Unless someone who's done it chimes in we may never know.
Old 01-17-2021, 03:17 PM   #13
parklane
parklane's Avatar
Yes, the 55/56 Fords had vacuum wipers. Someone at one time mentioned that tri year scrub wiper motors could be adapted to work.
If brains were wire, some couldn't short circuit a firefly
parklane is offline   Reply With Quote
Old 01-17-2021, 06:26 PM   #14
Alaska Jim
Alaska Jim's Avatar
I have heard, or read somewhere that the '57 chev wiper motor could be adapted, but I could be wrong. I would probably go with the newport motor. all the "bugs" have already been worked out for you, and you get a warranty.
Alaska Jim is offline   Reply With Quote
Old 01-17-2021, 09:25 PM   #15
KULTULZ
KULTULZ's Avatar
Post Re: wiper motor question
Read This -
http://57fordsforever.com/smf/index....63.0;topicseen
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
