Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 01-13-2021, 04:22 PM   #1
yohoc1
Default Model A rearend conversion
Looking for an adapter to convert Model A rear driveshaft to modern driveshaft yoke
yohoc1 is offline   Reply With Quote
Old 01-13-2021, 10:28 PM   #2
Andy
Default Re: Model A rearend conversion
Not possible.
Andy is offline   Reply With Quote
Old 01-14-2021, 12:17 PM   #3
Charlie Stephens
Originally Posted by Andy View Post
Not possible.
I would say "Not a good idea", but possible, see https://www.speedwaymotors.com/Speed...SABEgKupvD_BwE and others I am sure. Once you remove the torque tube you need to add brackets to stop the twist of the axle. The rear end isn't particularly strong. If you are going to build the brackets you should just go with a later rear end.
Charlie Stephens
Old 01-14-2021, 12:21 PM   #4
Charlie Stephens
This forum is for questions to the editors about the site. You should post your question here for better results: https://www.fordbarn.com/forum/forumdisplay.php?f=3
or since this is a non original situation you might have better results here:
https://www.jalopyjournal.com/forum/...ssage-board.5/
What is your overall plan? What engine?
Charlie Stephens
