03-23-2021, 09:09 AM | #1 |
Plans for the 30
Going to convert to 12 volt going with neg ground, Add turn signals, And a Mitchell tranny. Need help what parts I'm going to need for the 12 Volt conversion Also the best or better Turn signal kit to buy. I Now have a 6 volt 1 wire alternator now. Where to get 12v alternator?
03-23-2021, 09:24 AM | #2 |
Re: Plans for the 30
Take your present alternator to any Starter/Generator Electrical shop and get them to replace the regulator with a 12v unit. The ignition coil and the light bulbs are the two items that will need to be changed. I prefer the Tickin-in Thru Time turn signal kit.
I know you didn't ask for my opinion, but I think you changing to 12v is foolish when it already has an operable electrical system. |
03-23-2021, 09:35 AM | #3 | |
JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
03-23-2021, 10:00 AM | #4 |
I agree with Brent - A 6V alternator will handle everything on a stock A. The only trouble is finding any accessories that work with 6V positive ground.
JayJay also points out the motors must be converted to 12V, although a lot of 6V starters have survived abuse for many years. |
03-23-2021, 10:27 AM | #5 | |
JayJay
03-23-2021, 10:39 AM | #6 |
Cowtown A's |
03-23-2021, 01:10 PM | #7 | |
With regard to needing 12v accessories, I (-like many others) charge my cell phones and run my GPS when on tour with my 6 volt battery and charging system. The only reason I can think of for needing a 12v system is if you are in Jordan's part of the country where an A/C system has been retrofitted to the vehicle. For me, all my brass-era up to Model-As are all open cars, ...so I let Mother Nature be the 'fan'. |
03-23-2021, 01:18 PM | #8 | |
This really is not an issue, but even if it has someone concerned, switching the polarity is a simple thing to do. Remove the 6v battery and rotate it 180° and reconnect the cables. The biggest thing that often gets overlooked in this is changing the polarity of the ignition coil which just switching the two primary wires to the opposite terminal. If using a stock generator with a stock cut-out, then just re-flashing the generator generally allows the generator to correctly charge. If someone is using the diode-equipped positive ground cut-out, then switching to a Model-T 6v generator cut-out cures that. Then just reverse the polarity on the Ammeter and you should be set. The starter and the lights do not worry with polarity from my experiences. |
03-23-2021, 05:12 PM | #9 |
I run 12 v on all of my Model As. Changing the obvious coil, globes, dropping resistor for the horn and converting the starter to 12 volts are about all that is required. EASY!
Before I converted the first one, I considered the availability of parts in remote areas and about 3,000 miles into the next trip, we were in a smallish town and the coil failed. I was able to buy a new 12 volt one easily but I think I'd still be there if I had to have a 6 volt one. I got to like 12 v so much I then converted the others.
03-24-2021, 09:08 AM | #10 |
agree with Brent that 12V is totally unnecessary.
our Town Sedan starts quick, the lights are bright and the horn sounds perfect. all with an el-cheapo 6v battery from Tractor Supply or O'Reillys (whoever has the best deal when I need to replace). There are enough more neccessary projects always waiting that I would never consider a 12V conversion. GPS and cell phone charger will work on anything over 5v......
our next Model A is out there in the unknown...... |
