03-02-2018, 09:35 PM | #1 |
Adj alt brackets
Who sells the adjustable alt bracket for the bottom bolt on timing cover to alone belt thanks
03-02-2018, 11:35 PM | #2 |
Re: Adj alt brackets
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
03-03-2018, 11:22 AM | #3 | |
If you are looking for a bracket like 160B suggested, I have used (with a little tweaking) a tensioner bracket from a SBC. Much cheaper and easy to find. Last edited by Ruth; 03-03-2018 at 04:43 PM. |
03-03-2018, 05:44 PM | #4 |
I make my own because I use a second hand alternator bought from a wrecking yard. The shape of the bracket depends on which alternator you are using because the mounts vary from car to car. If you don't have the facilities to make one, maybe someone you know has.
03-05-2018, 09:53 AM | #5 |
I believe it is offically called a "fan belt tensioner"
Nu-Rex has them for about $5 http://www.nurex.com/fan-belt-tensioner |
03-05-2018, 04:13 PM | #6 |
I don't think there is such a thing. As a solution, see my earlier post.
03-06-2018, 10:21 AM | #7 | |
Move washers around to adjust belt alignment! https://parts.modelastore.com/show_Product.asp?ID=4057 |
03-08-2018, 01:28 PM | #8 |
I used the A10001ADJ bracket kit from Mike’s A Ford Able.It’s not cheap but is well made and fully adjustable. I used it to mount a small 1wire Denso alt on my A.
