08-24-2022, 04:54 PM | #1 |
Charging
Can't find original Post.
40 Coupe, 48 block, Petronix. Had the car re-wired last fall with all new harnesses. Car has never (4+ years) showed in the green on the voltmeter. Used to run on the low end of the yellow, This April it started at about 3/4's on the Red, ran fine. Then about 1/2, skipped and not full power. Had the generator re-built and matched to the regulator, Same thing. Took it back and he assures me it's putting out 7+ volts and 30 amps. Had someone help with a voltage reading today from the Batt terminal on the regulator to ground. .2 Volts. Battery stays charged. Right now I have an expensive piece of yard art. Any help/suggestions appreciated. Paul in CT |
08-24-2022, 06:34 PM | #2 |
Re: Charging
Paul if it was me I would retire the entire generator system and simply replace it with a 6 volt alternator. The common GM Delco alternator can be converted to 6 volts with an internal regulator there's conversion kits available to do it. Or look at what Speedway offers they have a 6 volt single wire alternator that will work perfectly as well. Going to the alternator you now have a one wire system just one wire coming from the alternator is now connected to the battery.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
08-24-2022, 08:30 PM | #3 |
Re: Charging
Fitting an alternator may not fix any of your problems, just skirting them possibly. Fix what you have and learn by it. Why have you started a new thread on this subject ? Regards, Kevin.
08-24-2022, 09:08 PM | #4 |
Re: Charging
Because I couldn't find the original.
Paul |
08-24-2022, 09:42 PM | #5 |
Re: Charging
