05-07-2020, 11:42 AM | #1 |
1 Fly wheel 2 PP thread bad
Hi guys, went to reinstall PP on flywheel & Murphy showed up on last bolt! Per 17-20’lb torque spec last bolt stripped thread in flywheel! I know all the options. 1 Different flywheel w/o prob. 2 Helicoil. 3 weld redrilled retap. Or my solution as I have a lathe I went to a 3/8”-16 tap/thread & drilled a concentric hole in the 3/8”-16 bolt to remove weight till same weight as 5/16-18 bolt using balance scale to achieve same weight so it should still be balanced. I don’t like Helicoils. Didn’t wanna heat up flywheel w weld! Don’t think I need new flywheel! So that’s what I did. Engine still out of car. Don’t beat me too much but what do u think of my solution?
Nomad |
05-07-2020, 12:00 PM | #2 |
Re: 1 Fly wheel 2 PP thread bad
Shade tree approach:
Line the stripped hole with a tube of tinfoil and put the original bolt in just tight enough that the lock washer is copressed so it will not come loose. The balance is preserved and the pressure plate could care less that it is fastened with five and a half bolts instead of six. Alternatively, fill the hole with JB Weld, drill it, tap it, and torque it to about half recommended value. |
05-07-2020, 12:04 PM | #3 |
I am not enamored with any of the above approaches. I would use a quality thread insert (Keen-Sert, etc.) and be sure.
05-07-2020, 12:58 PM | #4 |
Hope you don't fly,aircraft are one of the largest users you can find with heli coil approved repair scheme. On a side note welding cast iron and drilling and tapping will be another venture you should eliminate from your offerings.It becomes almost non machinable at best. "Tub" has also given sound advice
R |
05-07-2020, 02:16 PM | #5 |
Try a metric threaded bolt. Sometimes it will grab damaged threads and allow careful tightening when the SAE threads are worn or cross threaded.
05-07-2020, 03:16 PM | #6 |
Bruce
Works good Lasts long time |
05-07-2020, 04:29 PM | #7 |
05-07-2020, 04:32 PM | #8 |
I think your fix will work just fine. If your "new" bolt made torque and felt solid doing so, I don't see any reason to worry.
Terry
05-07-2020, 06:18 PM | #9 |
Thx all, I do agree welding cast & trying to reaching is a poor option. Keensert I agree is a good fix but don’t think significantly different than my fix which eliminates the extra piece of metal. No way on the drilling tapping a new pattern without a precision mill & turn table, have a horror story w a flywheel I had originally gotten w the vehicle that after several engine pulls & detective work realized it was .090 out of ci centricity causing major vibration due to out of balance condition! I did a test run & used another 3/8-16 bolt like the one I’m using in a junk flywheel I put same thread in & torqued to 30 ‘lbs w no problem. I will use the 3/8-16 bolt I modified to correct weight. 1 out of 5 of u agrees thx Terry, u & me makes 2 outa 5, that’s 40% LOL! Thx all for comments & not spanking me too hard! Being a machinist & having experience in dynamic balancing I believe it’ll b fine.
Best all A
Nomad |
05-07-2020, 06:37 PM | #10 |
It SEEMS pretty evident that some of y'all have never witnessed what's left after a clutch explosion. I remember two different occasions specifically back in the latter '60s, and it ain't nice! One guy lost a leg over it. That's one area that you couldn't make me cut ANY corners. You DO realize that those six bolts have specially-sized shoulders and lengths? Do yourself a huge favor and if you can't afford a new flywheel, at least round-up a good used one. At the very least do as suggested above and re-drill and tap (PRECISELY) at the 60 degree offset...…..did I say PRECISELY? And don't just go to Lowes and buy six grade 8 bolts.....get the proper, dedicated pressure plate bolts. But WTF do I know? DD
05-07-2020, 06:52 PM | #11 |
C512>>>I think your fix will work just fine.>>>
AG>>>thx Terry, u & me makes 2 outa 5,>>> Ditto. Probably makes it at least 3 outta 6 oops 7 now. 8^) Jack E/NJ |
05-07-2020, 06:53 PM | #12 | |
Scatter shield was installed soon thereafter.
05-07-2020, 06:54 PM | #13 |
A template? Really?
05-07-2020, 06:55 PM | #14 | |
05-07-2020, 07:14 PM | #15 | |
Ken |
05-07-2020, 07:18 PM | #16 |
OK. You can make that 3 1/2 out of 9, because I think what the O/P suggested is the best of the bad ideas.
But it's still a bad idea. I used to drag race too. |
05-07-2020, 07:22 PM | #17 |
Ya know, this is yet another of those threads that perplexes me.
Man oh man, I pray some of you guys are never near me on the highway. Some guys should simply put the wrench down, shut the lights off and leave the garage...
05-07-2020, 08:32 PM | #18 |
Wow! There’s the ass kicking I expected! While I still think my plan was viable considering the almost 20% larger hardware, I’ll go w a Helicoil fix staying w original 5/16-18 PP hardware. I asked for ur opinion so. As Ronnie indicated Helicoils r certified repair for threads in aircraft & aerospace industry so gotta b good for old fords
Nomad |
05-07-2020, 09:57 PM | #19 |
And as stated above, always use the correct shoulder bolts on the flywheels designed for them. Personally those flywheels are not difficult to obtain and are not rare. I would junk the flywheel with stripped hole and get another off the shelf.
05-08-2020, 01:11 AM | #20 | ||
Now that's funny! Is a cardboard template good enough? I guess using the pressure plate itself would complicate matters? Quote:
Now there's a perfect example of some good ol' MSM-like obfuscation. What Ronnie "indicates" ain't necessarily the WHOLE story for ALL parts in flyin' flivvers and space ships. With your mind seemingly made-up, I'm not sure why you even wasted your time asking for advice here to begin with. Just try VERY hard to imagine the scary stuff going-on inside that clutch housing with that flywheel/clutch spinnin' at even 2,500 RPMs. THEN try to imagine the tremendous multi-directional forces and loads imposed on those six, lousy 5/16" bolts screwed-into Helicoils when ya raise the RPMs to four grand and enthusiastically engage the clutch! GOOD LUCK, ol' buddy! I wish ya the best!! Just remember what deuce_roadster indicated....used flywheels are NOT hard to round-up. DD |
