Old 09-30-2020, 09:13 PM   #1
PeteVS
PeteVS's Avatar
Default "Poly" brake lines...
I've done a few brake lines (flared and bent) in steel. Next project I wound up using copper nickel which I much prefer. I don't even want to think about working with stainless. But our local parts house has "poly" lines. They're kind of an ugly dark green color but the guys who work there don't seem to know much about them. Can anyone explain them to me? Thanks!!
Old 09-30-2020, 10:03 PM   #2
Jay in Mass
Default Re: "Poly" brake lines...
I never heard of the poly brake lines. Hope that someone will chime in and let us know
about them.
Jay in Mass is offline   Reply With Quote
Old 09-30-2020, 11:50 PM   #3
Russ/40
Russ/40's Avatar
I've used them, and I didn't think they were any different except maybe the finish on them.
Old 10-01-2020, 04:58 AM   #4
51 MERC-CT
51 MERC-CT's Avatar
The "Poly" part is just a plastic coating that is applied to help prevent corrosion due to road salt etc.
Otherwise the tube has the same form-ability characteristics as copper-nickel tube.
Old 10-01-2020, 06:24 AM   #5
oldbugger
oldbugger's Avatar
i dont understand plastic coating on copper nickel. i thought copper nickel didnt get corrosion. Paul
oldbugger is offline   Reply With Quote
Old 10-01-2020, 06:39 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
Around here those poly covered lines rust out in under 10 years-- before the poly lines were used it was rare to have a rusted out brake pipe, perhaps 20 feet of pipe a year, now the shop uses over 100 feet of pipe a week--- use the copper nickel
Old 10-01-2020, 06:42 AM   #7
PeteVS
PeteVS's Avatar
Next time I go to get something, I'll take a magnet to see it it's just coated steel and I'll report back.
Old 10-01-2020, 07:07 AM   #8
51 MERC-CT
51 MERC-CT's Avatar
Where did you get the idea that copper-nickel brake line is poly-coated??
Old 10-01-2020, 08:33 AM   #9
wga
wga's Avatar
Goggle it
Underneath the PVF-coating is a double-wall, low carbon steel, copper brazed tubing which meets all international and U.S. requirements for brake tubing. The difference being that Poly-Armour offers 30 times the corrosion resistance of galvanized steel alone.
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 10-01-2020, 09:42 AM   #10
Mart
Mart's Avatar
It's standard steel brake pipe with a thin green plastic skin on it. I think it may have been (or might still be) OEM fitment for some manufacturers.
Mart.
Old 10-01-2020, 09:50 AM   #11
JSeery
JSeery's Avatar
Mart.
I know Ford uses it, on some models at least.
Old 10-01-2020, 05:04 PM   #12
cadillac512
cadillac512's Avatar
Mart.
This is correct.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 10-02-2020, 07:05 AM   #13
Frank Miller
Frank Miller's Avatar
i used a piece to repair a fuel rail on my truck. I used silicone bronze with a TIG to connect it so I'm guessing they are steel. Finish sanded off but seemd to be on there good.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 10-02-2020, 07:16 AM   #14
marko39
I replaced my rear lines on a daily driver after they rusted out. After about 5 or 6 years they looked like pretzel sticks.
marko39 is offline   Reply With Quote
