Old 02-09-2021, 06:10 PM   #1
1930artdeco
1930artdeco's Avatar
Default Running board prep
Ok so I need to replace the mats on my running boards. This will unfortunately be done on car so I need to see if I have the step correct.
1) put paper up around painted surfaces
2) remove rust to bare metal
3) prep metal and then use a primer on it
4) paint with either flat or gloss black
5) use gorilla glue
6) attach new mats and trim
Have I left anything off?
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 02-09-2021, 06:37 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Running board prep
Correct me if I'm wrong, but shouldn't the running board trim be removed in order to install the rubber mat that fits under the edge of the trim? That would require taking the boards off the car.
Mike Peters is offline   Reply With Quote
Old 02-09-2021, 09:44 PM   #3
1930artdeco
All I did was remove the front and rear bolts and unbent the long piece and I was able to remove it. But I have 60’s repo trim on the car so it may be different than the correct stuff.
Mike
1957 Country Sedan
