Old 11-06-2019, 02:20 AM   #1
34Pietenpol
34Pietenpol's Avatar
Default Black fender paint
Time to correct the front fenders on my ‘31 Mail Truck. When I got her, she had a welled left instead of the standard. And a standard right instead of the well for the spare. I found two good standard front fenders recently. Bill Gift in Chambersburg did a beautiful job installing a wheel well in the right one. They’re bead blasted, primed and under coated on the insides. Now prepping the primer for sealer and top coat.
Question is, what is your preference for the black top coat? Locally, Nason is available or Eastwood via the catalog. I could use Ranthane urethane from an aircraft supplier.
Point is, this is a driver that I want to take care of. It will never be judged without a total body rebuild. Factory original paint is not a priority. Good looks and durability are. Thanks!
34Pietenpol is offline   Reply With Quote
Old 11-06-2019, 07:28 AM   #2
jb-ob
Default Re: Black fender paint
The 'Correct Answer'......use what ever black the other sheet metal is painted in for a color match. Yes, there are different shades of black. What material did the original restorer use ?
That said, I'd stay local with Nason...and use their line of primers etc. for compatibility.
jb-ob is offline   Reply With Quote
Old 11-06-2019, 12:46 PM   #3
J Franklin
J Franklin's Avatar
I always thought the driver entered & exited on the right, thus the left spare.
Old 11-06-2019, 06:43 PM   #4
34Pietenpol
The Post Office spec was for a right spare well and sliding doors for driver safety. There was only one seat. The slider was a believed a safer way to exit into the road than with a swinging door. The curb side spare was considered safer as well.
Old 11-06-2019, 06:55 PM   #5
Lew
The sliding doors would allow the trucks to be parked closer when backed up to the dock for loading purposes.
Lew is offline   Reply With Quote
Old 11-08-2019, 07:58 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
I choose DuPont's Nason single stage urethane for its durability, ease of touch-up and comparable lower cost. Gloss without color sanding is excellent. Very little orange peel.
Bob Bidonde
Old 11-08-2019, 11:10 AM   #7
Mike the Grump
I'm not a painter. You might also want to check with the guy who primed them and ask what primer he used.
Make sure the products you're using are compatible with what he used.
Mike the Grump is offline   Reply With Quote
Old 11-11-2019, 03:26 AM   #8
34Pietenpol
Looking great. I’m thinking Nason is the solution for those reasons. Their sanding sealer will seal the primer already applied. Thanks.
Old 11-11-2019, 04:41 PM   #9
larrys40
I like and use a lot of sherwin Williams 2nd dimension single stage. Color sands and buffs great now and 10 years from now.
You have to get from sherwin Williams auto paint store or jobber.
larrys40 is offline   Reply With Quote
Old 11-15-2019, 08:38 AM   #10
Ed in Maine
I like to use acrylic urethane jet black (gloss) from TCP Global @ $59.96 per quart. Beautiful smooth gloss finish that looks like you could jumb into a black hole! Ed
Ed in Maine is offline   Reply With Quote
