Old 05-09-2021, 09:55 AM   #1
wright-47
Default 36 transmission sealed bearings
I can get sealed bearings for the input and output shafts on my 36 trans. Has anyone used these and would you remove the inner seal for extra lubrication from the trans oil? I know there is a drain hole in the front that can be plugged. I cant see any reason this won't work. There is a modern seal that fits the front carrier to put every thing back to "original" if I remove the seals on the bearings.
wright-47 is offline   Reply With Quote
Old 05-09-2021, 10:38 AM   #2
Veeder
Default Re: 36 transmission sealed bearings
I was wondering the exact same thing. This is a great question
Veeder is offline   Reply With Quote
Old 05-09-2021, 11:17 AM   #3
jimvette59
jimvette59's Avatar
Yes.
jimvette59 is offline   Reply With Quote
Old 05-10-2021, 06:52 AM   #4
Terry,OH
Terry,OH's Avatar
Exactly what I do, remove just the inner metal shield. Do not block any of the oil holes and use a modern seal for the front bearing retainer. Lube the input shaft a little bit of grease in the area of the seal.
Old 05-12-2021, 12:42 AM   #5
Oldcarbearings
Location: North Warrandyte, Melbourne,Victoria, Australia
I would use ONLY quality brand bearings : i.e. Fafnir (Timken), F.B.C, Federal, MRC, etc,
&Use original oil seal FORD part number: 74-7052 for front input shaft as it's metal cased /stepped &has a leather lip spring loaded & felt wiper ,
For the rear extension housing oil seal use FORD part number: 78-7052,
Same contruction/type as 74-7052 BUT NOT stepped,
These kind/type of oil seals are far better suited to the older style lubricants then modern neoprene rubber oil seals in our expereince.
Oldcarbearings is offline   Reply With Quote
