03-25-2021, 10:04 PM | #1 |
Mitchell OD with touring engine
Today I was coming home in my CCPU, still fairly new to me about 300 miles since I finished it. It has a stock motor with the exception of a 5.5 Head.
I have a 26% Mitchell which I love and use constantly as a gear splitter, this too is my first OD. I am wondering if a 36% might suit me better for a touring car I am contemplating. I am planning a touring motor, 6.1 head , Touring Cam, Counterbalanced crank, lightened flywheel, bigger valves, etc. Although I think the 26% will give me plenty of top speed, I am wondering if the 36% would split the second to third gap closer to center, making it a better mid range, and hill climbing car. Anyone have the touring engine, 36% combination with 3.78 gears that would care to comment?
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
03-26-2021, 06:25 PM | #2 |
Re: Mitchell OD with touring engine
I have run a Borg Warner OD for years with a stock engine. The Borg OD is a 33% increase. It pulled a bit hard, IMO. The engine was never quite up to the task. Then I installed a 26% Mitchell and all was well. and the engine now handles it well, 50 MPH is no longer a challenge. A 36% OD, to me is pushing any engine with only 3 main bearings. If your present 26% OD is working well, then maybe you you stay with that? Just my opinion.
03-26-2021, 06:37 PM | #3 |
Changed my car by running 30.5" tires and wheels on the rear..how about a 3.54 with the 26%?..changing overdrive ratio is just one way to change the outcome..
03-26-2021, 06:44 PM | #4 |
The only way I would run a 36% is with 4.11 gears.
03-26-2021, 06:51 PM | #5 |
I am also trying to get the 2nd over split a little higher, changing the gears doesn't do that.
03-26-2021, 06:52 PM | #6 | |
03-26-2021, 06:55 PM | #7 |
I would go for the Mitchell 26% O/D with the Mitchell 15% 1st and 2nd synchro trans. I love spending other peoples money...
03-26-2021, 08:51 PM | #8 |
That would actually be the best solution, but alas, is not in the budget. I have the synchro trans in another car, which I went with the standard first, 15% increased second. I really like that combo. Then add the 26% should nail it. So I guess I will stick with the 26% and maybe some day, I could add the tranny.
