03-20-2021, 09:11 PM | #1 |
Best graphite thickness
Hi guys sent an email to Best but I don't think they'll get back too me quick. Does anyone know the compressed thickness of their graphtite 507 head gaskets? Also any prep for them on install?
"Came too close to dying to stop living now!" |
03-20-2021, 11:27 PM | #2 |
Re: Best graphite thickness
Rob, I can't answer your question...these things disintegrate upon removing the head[s]....That is why, when I build an engine, i fit the heads with no gaskets in place and rotate engine at least two complete revolutions. If there is no contact, you can be pretty well assured of at least .040" clearance with gaskets torqued down.
03-21-2021, 05:54 AM | #3 |
BEST head gaskets compress down to about .050 to.053”. Slightly more with the copper clad type (ie perhaps another 2 or 3 thou).
VANPELT SALES LLC Cincinnati, Ohio Office: 513-724-9486 www.vanpeltsales.com www.classictransmission.com |
03-21-2021, 06:17 AM | #4 |
I wrote to them before I used them and they suggested that I spray both sides with copper spray.
03-21-2021, 06:49 AM | #5 | |
03-21-2021, 08:17 AM | #6 |
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
03-21-2021, 04:56 PM | #7 |
Right here... https://bestgasket.com/head-gasket-bore-thickness/
Or here... https://bestgasket.com/ford-big-bore/ |
03-21-2021, 05:34 PM | #8 |
Ronnie, thats good info', I took a set of copper ones off the other week that had only been on for a few hundred miles,I had sprayed them with c/coat all over, and thought about just around the coolant holes would have been easier.
Lawrie |
03-21-2021, 07:06 PM | #9 | |
Anyway Best did get back too me , which I didnt expect over the weekend and this is what came back : Hello Thank you for you purchase of our 507G Head Gaskets The compressed thickness is .053+/-.002” We recommend a copper coat spray such as K&W or Permatex on both sides of the gasket.
03-22-2021, 02:57 PM | #10 |
03-22-2021, 04:06 PM | #11 | |
Also, once they have been compressed, I do not use them again - as I'm not confident they will seal again. To me, the amount of time/effort it takes to disassemble, clean and reassemble the heads - doesn't make any sense to gamble as to whether or not the head gaskets will seal - so I always use new ones (regardless of type). The only place I don't is on solid dead-soft copper gaskets (race applications) . . . where sometimes I will anneal them and reuse them. |
03-22-2021, 10:12 PM | #12 |
I've been re using them for years, if there not damaged
03-24-2021, 06:10 AM | #13 |
03-24-2021, 05:20 PM | #14 |
03-24-2021, 06:29 PM | #15 |
Good to hear it as well. I've got a bunch hanging on nails in my shop ceiling because I just couldn't bring myself to throw them out.
03-24-2021, 09:29 PM | #16 |
I always reuse the copper clad type gaskets on the same engine block and heads they came off. Heck I have even reused the older type steel clad gaskets as well same way as above.
The gaskets seal perfectly when I use silver spray paint {3 light coats per side} on the gasket surfaces and a small amount of silicone sealer around the wafer holes on the block deck and the head surface areas. Ronnieroadster
