Old 01-06-2021, 02:07 PM   #1
S.Duncan
Default 32 roadster body dimension
I'm in the process of piecing together my long term 32 roadster project. Like many original roadster bodies it was completely disassembled for rear floor and subframe work. I'm looking for an outside to outside measurement between the top iron brackets on top of the quarter panels. Any help is appreciated
S.Duncan is offline   Reply With Quote
Old 01-06-2021, 03:12 PM   #2
Ronnieroadster
Ronnieroadster's Avatar
Default Re: 32 roadster body dimension
Just measured my original Henry Ford body this is what I get 50-5/16. I will tell you my body lines and door gaps are spot on.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 01-06-2021, 04:43 PM   #3
S.Duncan
Thanks Ron
Old 01-06-2021, 04:47 PM   #4
Krylon32
When we were assembling Brookville 32 bodies when they became available we made a simple fixture out of 3/4inch tubing with a piece of ready rod going thru it. Just put it between the top iron tabs to keep the measurement right without fighting it.
Krylon32 is offline   Reply With Quote
Old 01-06-2021, 05:26 PM   #5
Ronnieroadster
Originally Posted by S.Duncan View Post
Thanks Ron
Your welcome. The way Kylon32 used the tubing and steady rod is an excellent way to set a dimension.
