Old 12-16-2019, 08:37 PM   #1
keyswitch1
Default Welding question
I used my pro-mig Lincoln electric welder to install a patch panel on
my model a the other day.
It has been a long time since I used this and I forgot to hook the bottle up to
it. It is 75% percent argon and 25% carbon dioxde up.
Question is should I start over with welding the panel again[LIST]
Thank you for your help !!
keyswitch1 is offline   Reply With Quote
Old 12-16-2019, 08:42 PM   #2
holdover
Default Re: Welding question
the gas acts as a shield, without it the weld may look terrible and not be sound.
holdover is offline   Reply With Quote
Old 12-16-2019, 09:33 PM   #3
1ton
My guess is that you already have the answer to your question. Go with it and you will be happier in the long run.
1ton is offline   Reply With Quote
Old 12-16-2019, 09:36 PM   #4
Dennis Pereira
Dennis Pereira's Avatar
I think I would grind the welds and have a look .
Dennis in Kelsey ca
Dennis Pereira is offline   Reply With Quote
Old 12-16-2019, 09:42 PM   #5
midgetracer
midgetracer's Avatar
Without the Ar/CO2, the welds must look bad and have no strength. Grinding them will show lots of pin holes.
midgetracer is offline   Reply With Quote
Old 12-17-2019, 08:10 AM   #6
77Birdman
Are you sure you didn't use a flux core wire? One time I forgot to turn the gas on and I couldn't get the weld to work for *&*(*&, then I realized what I didn't do.
Having said that I would follow the #4 post. Then re-weld as necessary, be careful with the heat.
77Birdman is offline   Reply With Quote
Old 12-17-2019, 08:49 AM   #7
Nosetime
Nosetime's Avatar
agree with Birdman. You may have flux wire in the machine, it should have welded and looked like shit with the gas off. Check your wire spool.
Nosetime is offline   Reply With Quote
Old 12-17-2019, 09:31 AM   #8
Joe K
Joe K's Avatar
Gosh I love my MIG (Lincoln SP135) The sound when you get it "right" (frying eggs) is like music to my ears.
Want to re-learn use of a MIG? Try welding aluminum using the special "kit" and pure argon. It works - kind of.
Joe K
Shudda kept the horse.
Old 12-17-2019, 12:15 PM   #9
d.j. moordigian
d.j. moordigian's Avatar
The pin holes are " porosity "..
You may even see through the weld! Weld with porosity is NOT a good weld..
The fellow that did the welding,..Look up the word porosity.
d.j. moordigian is offline   Reply With Quote
Old 12-17-2019, 03:41 PM   #10
whirnot
whirnot's Avatar
Joe K
Welding aluminum with a mig just takes practice. I once welded two pop cans together with one.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 12-18-2019, 12:12 AM   #11
GB SISSON
GB SISSON's Avatar
Pin holes and bubbles galore when I forget to turn on the gas. It is very ugly without the gas and you can just break off a bolt welded to a piece of strap with it....
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 12-18-2019, 05:16 PM   #12
keyswitch1
It took me awhile but decided to do it YOUR way and the best part the welds are a lot better !!!!!!!!!!!!!!! I think five cars may be to much at 72 ?
? Thank you all very much !!
