04-05-2021, 08:32 AM | #1 |
Repairing radiator puncture
There I was, refilling my radiator after installing my new cylinder head, and I start to hear drip, drip, drip. Turns out, somehow I must have bashed something into it while doing all my work over the last four months. Or possibly it's a prior puncture that came unsealed while the radiator was dry.
The location is at the lower right corner, if you're in the car looking forward. It's only leaking to the inside, not out to the front, which suggests to me that the hole is toward the inside. Anyone have any pro-tips for a good epoxy to use for a repair, or what technique to use to get a good seal the first time? |
04-05-2021, 08:49 AM | #2 |
Re: Repairing radiator puncture
Solder it up. Clean it well, ...then clean it some more. Then clean it with a soft flame and use flux to clean the tube and allow it to stick. I purchase my flux from Johnsons in Iowa.
If you must, tear the fins loose carefully from the tube to access the puncture, then use a small set of needle-nose pliers to move them back into the proper position. A kiddie swimming pool can be your radiator tank, so fill with water to test. Use about 3 lbs of pressure to check. A exhaust on a shop vac will suffice, so just attach the hose to one of the inlets. Install the radiator cap, plug the overflow with a piece of fuel line hose and a bolt, and use your palm to block the other inlet/outlet. |
04-05-2021, 08:55 AM | #3 |
If I've never soldered before, is this a good job to learn on?
04-05-2021, 09:07 AM | #4 | |
I've been soldering since the dawn of time, and I would not recommend using a radiator as a learning tool...it just takes some practice to get the feel of solder flow and you don't want to inadvertently un-solder what's already there. However, using an epoxy-type product for limited punctures, such as JBweld would work just as well. Cleaning the area and having it dry is critical, of course. Tom Last edited by kawagumby; 04-05-2021 at 09:12 AM. |
04-05-2021, 09:09 AM | #5 |
Depends, ...what is the radiator worth to you? Experience is generally something you get after you need it. If this radiator is really nice, maybe take it to a professional is the most prudent thing. Remind me the next time you are here and I will give you an old A radiator to practice on.
04-05-2021, 09:11 AM | #6 | |
04-05-2021, 10:53 AM | #7 |
04-05-2021, 09:12 AM | #8 |
As many posts as you do i think you can pull i off .You seem to know alot so you are a good learner Go for it Also a couple of teaspoonful of black pepper will work
04-05-2021, 09:31 AM | #9 |
heard of a fella who just emptied the rad- squeezed in some black silicone from the back
and 10 yrs later was dry as the desert............. maybe not as good as solder, but worked well for him. |
04-05-2021, 09:55 AM | #10 |
That's the kind of thing I might do but then never admit to the guys on this board.
04-05-2021, 06:19 PM | #11 | |
Expose the area that is leaking and clean it well. Cut a piece of black cotton t-shirt material slightly larger than the area of the leak and saturate it with black silicone gasket sealant. Apply the saturated patch over the leak and smooth it on. The thinner the finished patch the more flexible it will be. A thick blob of silicone is not what you want. I used this fix on my AA radiator 10 years ago and it has not leaked since. I've also use the same type of repair on chest waders, coolers a hot tub etc... with good success.
Dave / Lincoln Nebraska |
04-06-2021, 07:42 AM | #12 | |
04-05-2021, 10:59 AM | #13 |
Discretion something something something valor, etc.
04-05-2021, 11:06 AM | #14 |
Your luck its on the inside, black radiator paint is your new friend.
04-06-2021, 12:01 AM | #15 |
Good to know. I found a place that will try the repair. If I were planning to keep the car awhile, I might do the silicone fix, but I intend to sell this one in a couple years, and I don't want a buyer to see that and think I'm the type to cut corners (not implying that you are, of course).
04-06-2021, 06:25 AM | #16 |
Alexiskai, I just sent you a PM
1930 Standard Coupe |
04-06-2021, 07:30 AM | #17 |
You don't want to develop soldering skills on your only radiator. It is an acquired skill that takes some practice and experience to perform...shame you aren't closer, I have some practice dummies. Ive actually saved a few radiators back flushing with an industrial hot water pressure washer with chemical degreaser, and soldering them up where needed.
04-06-2021, 08:28 AM | #18 |
Most radiator shops will rip out the tube at each end and solder over the hole in the tank, it will look ugly, for a small hole in the tube on the face of it gently pushing the fins away, carefully scraping to bright copper and soldering with iron is something I have done, if the fins are pushed back the repair can disappear, a torch can easily get the area too hot and pop other solder joints,
Not all solders are equal, I have seen a lot of bad soldering, most times there's several factors in the failure, , much of soldering is preparation, choice of flux and solders, getting the surface hot enough, but not too hot, the "no lead" solders melts at too high temperatures for this work, 50/50 solder , or good 60/40 electronics solder would be what I would use with acid flux after scraping with knife and rubbing with coarse skotchbrite piece held in tweezers/ hemostat till bright, then if in middle of tube either weller gun or electric soldering iron. I have also used epoxy, this repair on my truck is over 25 years old, it was " marine Tex" epoxy, looks ugly, but has worked |
04-10-2021, 08:48 AM | #19 |
Follow up: local radiator shop put it under water and detected two additional leaks. They soldered those up, tack welded repairs where the frame had rusted, and gave it a fresh coat of paint. $160
04-12-2021, 05:10 AM | #20 | |
You are fortunate to find a radiator shop that actually does repairs. Radiator shops around here just want to replace with a new radiator. Sent from my iPhone using Tapatalk |
