Old 05-20-2010, 06:37 PM   #1
RJD
Default Cracked Block
My 40 pickup's stock engine is cracked 3"along the pan rail between the pan screw holes and the edge of the block. And an inch into the inner side of the block L shaped, At the center bearing. I think it was caused by frozen water because it doesn't appear to be stress. any thoughts on a fix?
RJD is offline   Reply With Quote
Old 05-20-2010, 06:44 PM   #2
uncle max
uncle max's Avatar
Default Re: Cracked Block
If it's into the web, it's fatal.
uncle max is offline   Reply With Quote
Old 05-20-2010, 07:04 PM   #3
oldford2
oldford2's Avatar
Call Frank Casey in MA. He has been stitching cast iron for 40 years. Recently did a 221 block for me. Describe your situation and see what he says. Where are you located? Frank is a nice guy.
508-865-6613. John
oldford2 is offline   Reply With Quote
Old 05-20-2010, 08:06 PM   #4
Bob/Ohio
Bob/Ohio's Avatar
I welded a 409 Chevy block that had an 8'' crack on both sides from freezing. As long as it is just the outside of the block that got pushed out it will weld fine, but you can't always see what has happened on the other side. The old cast iron was good cast and it welds just fine. If you weld it, have it magnafluxed or pressure tested after to make sure you repaired all the crack.
Bob/Ohio is offline   Reply With Quote
Old 05-20-2010, 08:39 PM   #5
Ross in East Texas
Ross in East Texas's Avatar
Send a message via AIM to Ross in East Texas
A good cast iron repair shop can repair all but the very worst blocks. Search out a good shop and get an estimate.
Ross Murphy
1939 Ford Standard Coupe
Ross in East Texas is offline   Reply With Quote
Old 05-20-2010, 08:40 PM   #6
flatheadpete
flatheadpete's Avatar
Repairable. Call Mike at H&H. They can fix damn near anything!
flatheadpete is offline   Reply With Quote
Old 05-21-2010, 12:24 AM   #7
55 dude
55 dude's Avatar
here is the contact info for the guy that fixes all the Lemay Museum Cars, his name is larry and he has been fixing all my cast stuff for many years. http://www.localcarsdealers.com/wash...-cast-inc.html
55 dude is offline   Reply With Quote
