12-24-2020, 08:47 AM | #1 |
46 Ford inside door opener spring
On the shaft where the door handle attaches IN the car, there is a hair pin type spring at the base of it. This is on the mechanism behind the door panel. Mine has snapped or broke. Can I just buy this spring somewhere or do I need to find entire assembly. Im sure all models have same spring even if door opener mechs may vary abit in style. Thanks!
12-24-2020, 12:48 PM | #2 |
Re: 46 Ford inside door opener spring
Not quite sure of what spring you are looking for, can you post a picture?
12-24-2020, 12:58 PM | #3 |
That spring should be available from your favorite V-8 vendor. It can be a little tricky to change.
12-24-2020, 01:00 PM | #4 |
This may help.
https://www.google.com/search?q=1946...hrome&ie=UTF-8 Take photos "before" you start taking latch apart. |
12-24-2020, 01:54 PM | #5 |
