07-21-2019, 09:58 PM | #1 |
Identify Column Drop
I am trying to identify a column drop on a steering column that I got with a '34 Vicky. The steering box, Model No. B-3550, I believe is a '32 Ford steering gearbox. But the column drop does not look like any of the '32 column drops I have seen. It may be a '40 Ford, but I am not sure. I have attached a few pictures.
07-21-2019, 10:02 PM | #2 |
Re: Identify Column Drop
It’s 40.
07-22-2019, 08:37 AM | #3 |
Definitely '40.
07-22-2019, 08:41 AM | #4 |
All '32-'34 steering boxes were the same and therefore all had the same part number, namely B-3550, although not all of them had that number on the casting.
07-22-2019, 10:18 AM | #5 |
Thanks everyone for the quick response. I didn't know you could put a 1940 column drop on a 1932-34 steering column. I am guessing the steering shaft must be a '40 to match the locking mechanism. The shaft simply has a hole in it.
07-22-2019, 11:08 AM | #6 |
