Old 12-08-2018, 01:16 AM   #1
Pandersen33
Pandersen33's Avatar
Default Wiring help
Had a small fire today as a result of what appears to be a jammed brake light switch. Snowballed into the alternator wire and up into the terminal. Anyways i was trying to figure how how to prevent this in the future. Specifically if anyone has had luck using in-line fuses and if so what size? So far it looks like i’ll just be needing some new wires and a brake switch. Thankfully i had JUST put the fire extinguisher in the back of the car!
Pandersen33 is offline   Reply With Quote
Old 12-08-2018, 01:33 AM   #2
midgetracer
midgetracer's Avatar
Default Re: Wiring help
I like the safety fuse that mounts on the starter. It usually has a 20 or 25 amp fuse and is a fail safe when you have a short that might burn the car up. I know some don't like it, but for about $10 it provides a way to keep the wiring from burning up the car in a dead short situation.
midgetracer is offline   Reply With Quote
Old 12-08-2018, 01:55 AM   #3
31 Vicky
And install the A&L brake light switch.
The other available switch can fail by shorting to ground!
A's Always Dave
31 Vicky is offline   Reply With Quote
Old 12-08-2018, 03:26 AM   #4
Y-Blockhead
Y-Blockhead's Avatar
Our club just had the second wiring fire this year. I have given several of the safety fuses away at our monthly meetings... People just don't get it.
I run a 30a circuit breaker for my main fuse and a 20a on the lighting circuit.
Old 12-08-2018, 03:26 AM   #5
Y-Blockhead
Duplicate post...
Old 12-08-2018, 04:36 AM   #6
Synchro909
Synchro909's Avatar
Does the fuse on the starter cut power to the ignition if it blows? If it does, I'm not in favour. It's not hard to imagine a dangerous situation quickly arising if it were to blow on a busy road and the motor goes dead. I believe the ignition should not be fused but all else (except the starter!!), yes.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 12-08-2018, 10:03 AM   #7
katy
katy's Avatar
Ditto
Old 12-08-2018, 10:43 AM   #8
Ed Wendell
Ed Wendell's Avatar
If I had an electrical fire on any road, busy or not, the motor stopping is the last thing I would worry about.
I use the fuse mounted to the starter. I park our car in a cargo container and want to make sure everything is dead so I installed a battery disconnect switch.
Ed
Ed Wendell is offline   Reply With Quote
Old 12-08-2018, 11:14 AM   #9
Pandersen33
How are you isolating the lighting wiring from the main? Im assuming the 30a fuse is the safety fuse setup on the starter.
Old 12-08-2018, 11:24 AM   #10
cpf240
cpf240's Avatar
Probably a fuse at the generator cutout where the lights and horn get their power.
cpf240 is offline   Reply With Quote
Old 12-08-2018, 01:10 PM   #11
Badpuppy
A 20A fuse at the cutout to the lighting switch and horn will open those circuits if a short occurs. The fuse mounted on the starter is intended to prevent the battery from discharging into the generator field through a shorted cutout after the engine is shut off. if either or both fuses open during operation, the ignition will still be powered from the generator.
Badpuppy is offline   Reply With Quote
Old 12-08-2018, 02:39 PM   #12
Roadster62
Roadster62's Avatar
That is the impossible thing about understand electricity, nobody explains things the same way. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 12-08-2018, 05:50 PM   #13
Y-Blockhead
That is correct. The wire coming off the alternator to the lights/horn is fused with a 20a circuit breaker. The circuit breaker is "hidden in the frame rail by the alternator.
Old 12-08-2018, 10:23 PM   #14
dansluck
Send a message via AIM to dansluck Send a message via Yahoo to dansluck
I have 30 amp at starter and 20 amp at cut-out. Thanks Pandersen there has been some great responses.
dansluck is online now   Reply With Quote
Old 12-09-2018, 10:12 AM   #15
DHZIEMAN
The Model A I purchased had a short in the headlight circuit. Burnt up low beam wiring. Replaced it and then,
I installed a fuse block and 30A Fuse at the starter. Works fine!
Also double checked all wiring to make sure all was working and properly wired.
DHZIEMAN is offline   Reply With Quote
Old 12-09-2018, 10:32 AM   #16
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
I always put an inline fuse in the brake lite switch because if there is a problem, it is a long way under the car to get at it on the road.
Jacksonlll is offline   Reply With Quote
Old 12-09-2018, 11:05 AM   #17
ArtimusGordon
I use a 30 amp ckt breaker on the starter and I also installed a battery cutoff switch in front of the drivers seat. I also lost my coupe to a wiring fire a couple of years ago. (You can search for pictures on a previous post ( search “ SAD DAY” ) .
ArtimusGordon is offline   Reply With Quote
Old 12-09-2018, 11:14 AM   #18
ArtimusGordon
Try in search “fire”. Scroll down to “Sad day” for pictures of my totaled Coupe. 😠
Old 12-14-2018, 04:47 PM   #19
TJMack
I had a couple issues with my brake light switch when I first got my coupe. You might find this thread interesting. just paste it into your search bar. it will take you to the thread.
https://www.fordbarn.com/forum/showt...e+light+switch
TJMack is offline   Reply With Quote
Old 12-15-2018, 12:47 PM   #20
slammin
slammin's Avatar
Even though all the wiring is new, I took the same approach. Plus I added a battery disconnect under the drivers seat. When I pull the car inside, I shut off the gas and throw the disconnect switch. Prior to adding the switch, I pulled the battery ground cable.
slammin is offline   Reply With Quote
