12-02-2018, 06:36 PM | #1 |
1948 Tudor Sedan fuel line mount on firewall
Does anyone have a picture of their fuel line mounted to the firewall inside the engine bay? I am running a new line and want to correctly mount it in the oem location. Unfortunately, I can’t remember where that is.
Aaron |
12-03-2018, 12:53 AM | #2 |
Re: 1948 Tudor Sedan fuel line mount on firewall
This is the grimy original setup on my 46. The line ran along the DS frame rail to the firewall clamp.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
12-03-2018, 04:29 PM | #3 |
Perfect. Thank you
12-04-2018, 04:46 PM | #4 |
48Ford. I had to install a new line to the fuel pump and a clip for the firewall, as the PO had installed an electric pump at the rear, and an ugly pressure regulator on the firewall with an odd hose to the fuel pump. I had to make an assumption as to the location for the clip, as there was a screw hole in the firewall that lined up with where the clip fit best in supporting the line from the tank, and the routing of the hose to the pump. I got the clip P/N: 18-9296, and the hose P/N: 18-9288-A from Carpenter.
12-04-2018, 09:16 PM | #5 |
