Old 07-25-2016, 04:01 PM   #1
itslow
itslow's Avatar
Default Overall Vehicle Dimensions
Does anyone happen to have, or know of a website that has, a listing of the length x width dimensions of the early V8 model years? I'm looking for assembled dimensions from bumper to bumper and outside of fender to outside of fender; not just the easily obtainable chassis dimensions. The '32 and '33/34 dimensions would be of particular interest.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 07-25-2016, 04:14 PM   #2
JSeery
JSeery's Avatar
Default Re: Overall Vehicle Dimensions
Are you looking for a specific year? Looks like you can find this information online (at least some of it) and in the Reference Books.
Old 07-25-2016, 04:22 PM   #3
JSeery
JSeery's Avatar
Here's a 34.
Old 07-25-2016, 04:37 PM   #4
Bruce Lancaster
That restorer's guide series is pretty cheap and available for '32, '33, and '34. The drawings are actually from the Ford Salesman's manuals, which are rare and expensive.
Old 07-25-2016, 04:38 PM   #5
truckdog62563
truckdog62563's Avatar
The best sources for this info are the salesman/dealer handbooks produced each year that contain schematic drawings for each model. I have several, but my earliest is 1941. The other source is The-Blueprints.com were I found the below pics. Stu
https://www.the-blueprints.com/bluep...s/ford/page/1/
Stu McMillan
Marmon-Herringtons
truckdog62563 is offline   Reply With Quote
Old 07-26-2016, 09:05 AM   #6
itslow
itslow's Avatar
I'm primarily interested in the '32 and '33/'34 since those are the years that I have, albeit in disassembled form. I do have the multi-volume books for these years, but unfortunately they are packed away in storage at another location and are not accessible to me right now.
The others years would be helpful simply for future reference.
It looks like the overall length is relatively easy to find, but the overall widths appear to be a different story.
Mike
Wanted:
- ARDUN parts
Old 07-26-2016, 09:20 AM   #7
truckdog62563
Here's width info on the 36 half ton. I'll continue to look to see what else I have archived. Stu
Stu McMillan
Marmon-Herringtons
Old 07-26-2016, 09:21 AM   #8
LBs 37V8
LBs 37V8's Avatar
Mike - the 33-34 open cab pickup measured 66 1/4" in width. Same as closed cab pickup. Length of each truck was 179 1/2", but you may already have that. These dimensions are measured from outside fender to fender and outside bumper to bumper.
Measured Drawings are from the EFV8 1933-1934 Ford restoration manual, page G-16.
I don't have the 32 information. Bryan
If you want any info on car models I have that as well.
LBs 37V8 is offline   Reply With Quote
Old 07-27-2016, 01:29 PM   #9
scooder
Originally Posted by JSeery View Post
Here's a 34.
Don't spose you got the 34 roadster pic like that have you?
Thanks,
Martin.
scooder is offline   Reply With Quote
Old 07-27-2016, 02:26 PM   #10
JSeery
JSeery's Avatar
I just found them online, I could look and see if anyone has one posted.
Old 07-27-2016, 04:14 PM   #11
trevo
itslow my 34 vertically above the front wheel centres from mudguard outside to outside is 1720 mm
trevo is offline   Reply With Quote
Old 07-27-2016, 08:41 PM   #12
itslow
itslow's Avatar
Originally Posted by LBs 37V8 View Post
Mike - the 33-34 open cab pickup measured 66 1/4" in width. Same as closed cab pickup. Length of each truck was 179 1/2"...
Thanks for the measurement; that's actually one I was specifically looking for since I too have an open cab. I have a suspicion the trucks are the same overall width between '32 and '33/34 since the beds and fenders the same width.
Mike
Wanted:
- ARDUN parts
Old 07-28-2016, 01:49 AM   #13
scooder
I had a look, can't find one yet.
Thanks,
Martin
Old 07-28-2016, 06:16 AM   #14
JSeery
JSeery's Avatar
Thanks,
Martin
They should be around somewhere! I'm sure they were produced as part of the original promotional material, it's just a question of where to find them now!
Old 07-28-2016, 09:38 PM   #15
alchemy
alchemy's Avatar
Information for all, a 32 Ford will fit in a 68" x 164" rectangle.
alchemy is offline   Reply With Quote
