11-17-2010, 05:46 PM | #1 |
1932 and 1933-34 Cab Mounting Wood
I see that the various vendors lump these three years together when it comes to the cab mounting wood. Are these pieces indeed usable between the years? Are the heights and contours the same? I do know that the length and hole locations of the forward pieces are not the same between the years, but are the height and frame-side contour the same?
Which vendors sell the correct '32 parts? I've found the set I have is obviously for a '33/34 (given the length and holes of the front 2-pieces) and leaves the body sitting on the frame instead of the wood.
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
11-17-2010, 07:37 PM | #2 |
Re: 1932 and 1933-34 Cab Mounting Wood
I bought 32 cab specific wood from Macks Reproductions in Missouri and all the holes lined up and when I got done so did the hood.
11-17-2010, 10:21 PM | #3 | |
Roy Nacewicz |
11-19-2010, 11:21 AM | #4 |
Roy, you need to add these blocks to your product line!
11-19-2010, 03:43 PM | #5 |
Cauton all; The old original wood is usually shrunk and copies frequenty let your body contact the frame. Newc
11-19-2010, 04:37 PM | #6 |
Bruce |
