02-07-2023, 06:41 PM | #1 |
What Ford 6 cyl. used these spark plugs?
Have 2 sets of Champion 860 spark plugs still in factory boxes. 6 plugs per box, so would assume they are for Ford 6 of some vintage. Specific application is a mystery, but side of boxes reads: "Specially engineered for Ford vehicles".
I've tried Google to help ID them, but coming up empty. Anyone know of a vintage spark plug application guide out there? Appreciate any leads. |
02-07-2023, 07:00 PM | #2 |
Re: What Ford 6 cyl. used these spark plugs?
A quick google session seems to indicate it is a small engine plug. Champion's own site says "No automotive application". Don't know why they say engineered for Fords, unless that was a reference to Champion generally (doubt it).
02-07-2023, 08:17 PM | #3 |
The boxes look to have a window. The product inside shows thru the window. Maybe those small engine plugs did not originally come in those boxes?
Six in a box does not necessarily indicate for a 6 cylinder engine. I have bought eight plugs and get a box of six, and two loose ones. I figured the manufacture packaged them as a six-pack because six plugs was a common quantity purchased. |
02-07-2023, 08:40 PM | #4 |
I think the 223 6-cylinder Fords used them but the V8s definitely did. The F11Y replaced them and the BF42 was likely the factory plug but the 860 is in the same category. I don't know about heat range though. The 860 and 870 may be different heat ranges.
Spark plug numbers are fickle. Any little change and the whole number changes. this link shows the 860 and 870 or the F14Y in the same category. The F11Y replaced the F14Y around 1958 but they may be backward compatible. The heat range is what a person has to watch for. https://www.etsy.com/listing/1155778...ion-spark-plug Last edited by rotorwrench; 02-07-2023 at 08:57 PM. |
02-07-2023, 08:52 PM | #5 |
If you do a search they show for small engines. https://www.amazon.com/Champion-860-...53814599&psc=1
02-07-2023, 09:14 PM | #6 |
At least I can buy 8 individual plugs now, not a box of 10 like back in the day. |
02-07-2023, 09:33 PM | #7 |
Thanks guys for all the input. The reference chart that rotorwrench posted the link for held the answer. If I'm reading the chart correctly, the plugs fit 1957 Ford 292 (and perhaps 312) V8. Still strange to me why Champion would sell 6 plugs in a package for an 8 cylinder engine.
02-07-2023, 10:19 PM | #8 | |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
02-07-2023, 11:50 PM | #9 | ||
Ever wonder why you can't buy a package of hot dog buns in a quantity to match the hot dogs you picked out?
Alan |
02-08-2023, 02:37 AM | #10 |
When I was a mechanic, in the '60's, the shop bought their plugs 10 to a box. We'd take out 4, for a six and 2, ford a 8 cylinder.
It never made since to me, either but, that's the way it was. I just figured it was for bulk buyers that would by in multiples, like 60 for 6's and 80 for 8's. That's the only thing that made since to me.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
02-08-2023, 08:06 AM | #11 |
I think they are 14mm. Fords used 18mm with a taper seat like that.
From Rockauto: |
02-08-2023, 08:50 AM | #12 |
Since they are 14mm thread they will work with earlier Ford V8 and 6 cylinder engines, I'm going to try them in my '40 to see how they run. I should be able to determine if the heat range is right after running a few miles and then pull them to check electrode color/condition.
02-08-2023, 09:05 AM | #13 |
Ford didn't use a taper seat except in a 18mm. I don't think they will work for you in a 40.
02-08-2023, 10:06 AM | #14 |
860 and 870 Champion are the Ford TRUCK lower and higher heat range Spark Plug..... They are 18 mm Ford spark plugs....
The 1940 Ford uses the H10 / now H10C Champion spark plug... 14 mm -- they used that plug all the way up to 1954.... You will N O T be able to thread in an 860 Champion plug into you spark plug well for obvious reason....... |
02-08-2023, 10:10 AM | #15 |
18mm then. The internet gave me duff info.
Maybe the OP could have a look at one and confirm the thread size. |
02-08-2023, 12:08 PM | #16 |
How about a picture of the plug because I'm finding the same information as Mart.
02-08-2023, 01:40 PM | #17 |
Sorry, I had a brain fog moment. Plugs won't fit my flathead.
02-08-2023, 03:21 PM | #18 |
Mart, you were probably thinking in Whitworth......
02-08-2023, 03:41 PM | #19 |
When Champion obsoleted a spark plug, they were gone off of their replacecment charts unless a person can find older cross reference charts that list them and then go on to modern charts from there. Flathead Fords were limited to short reach and flat gasket type bosses so that's why they were only used on small engines after that. Various other small engine plugs have replaced some pf the older flat boss gasket type plugs. A lot of them are 3/4" or other smaller sizes now where the old ones were 13/16. Suffice it to say that the modern 860 spark plug is not the same as the old obsoleted 860 plug of the 50s.
Temporary flea-pay link to older long body 860 spark plug: https://www.ebay.com/itm/14492659158...Bk9SR4jJgazGYQ Modern short body 860 also described as a diesel glow plug: https://www.ebay.com/itm/26610494970...epid=193845518 The tapered boss plugs were new in the Overhead valve era since there was less worry about reach with them but then the core electrode placements started changing to get the spark in a more advantageous spot in the combustion chamber. This opened up a million new plug types Last edited by rotorwrench; 02-08-2023 at 03:46 PM. |
02-08-2023, 03:44 PM | #20 |
Photo confirms they are 18mm. As previously stated, they fit '57 Y block Ford 292 & 312 V8 and some 6 cylinders from around that same time.
