Old 12-01-2018, 02:59 PM   #1
davehc
davehc's Avatar
Default Easy Oil Pan Baffel Removel
Thought I would share how I removed the baffle from my oil pan after I finally got if off , for those who haven't tried this yet . . I used my slide hammer with the small hook , with a rubber cap to protect the baffle , hooked it in the small hole side of the baffle , and it popped out on the second slide .
davehc is offline   Reply With Quote
Old 12-01-2018, 07:19 PM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Easy Oil Pan Baffel Removel
Good idea .
Old 12-01-2018, 07:47 PM   #3
DKnapp
Hold the oil pan bottom side up and drop it on the garage floor. The baffle will pop right out.
DKnapp is offline   Reply With Quote
Old 12-01-2018, 08:06 PM   #4
Tom Endy
Tom Endy's Avatar
I use the wooden handle of a hammer. I slip the wood end into the opening for the pump and with the flip of a wrist it is out. A wooden baseball bat works even better.
Tom Endy
Old 12-02-2018, 12:31 PM   #5
Jim Brierley
I do like Tom does only I use a crowbar. They come out easily so no damage is done.
Old 12-02-2018, 02:35 PM   #6
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
I do like DNapp but I do it on the lawn. Don't want to scratch my pan :-)
Richard in Anaheim CA is offline   Reply With Quote
Old 12-02-2018, 03:09 PM   #7
Jeff/Illinois
Jeff/Illinois's Avatar
Good ideas all.
Old 12-02-2018, 03:44 PM   #8
Aretino
Aretino's Avatar
what is the logic behind removing the baffle?
Aretino is offline   Reply With Quote
Old 12-02-2018, 03:51 PM   #9
davehc
davehc's Avatar
For me , it is so I can "COMPLETELY" clean the pan .
Old 12-03-2018, 10:42 AM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
Most of the sludge is under the dipper tray, and it needs to be scraped out.
Old 12-03-2018, 06:27 PM   #11
rocket1
you know how most things fall apart when you drop them!
rocket1 is offline   Reply With Quote
Old 12-04-2018, 02:15 AM   #12
redmodelt
redmodelt's Avatar
I do the turn upside down drop thing too but with something on the floor for the gunk to splatter on.
Old 12-04-2018, 10:09 AM   #13
Jacksonlll
Jacksonlll's Avatar
Above all, make sure you respect those very sharp edges of the stamping. You don't need a giant cut.
Old 12-04-2018, 10:10 AM   #14
Purdy Swoft
I agree with post number 12 . The oil pan that I dropped on the lawn killed the grass where the gunk splattered . It was quite a while before the grass returned to cover the bare spot .
Old 12-04-2018, 10:28 AM   #15
Oldbluoval
Oldbluoval's Avatar
Aretino- this is not meant to be a Smart A** answer but the dipper pan goes back in.
It is for clean out only. Leaving it out would deep-six the engine in short work.
Old 12-04-2018, 11:36 AM   #16
Aretino
Aretino's Avatar
Thanks, cleaning makes sense.
Old 12-04-2018, 11:58 AM   #17
Tom Wesenberg
Good point. I didn't even think about how "removal" could have been taken both ways.
I read once where someone forgot to reinstall the dip tray during their engine rebuild.
Old 12-04-2018, 01:01 PM   #18
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
Place the pan in a large plastic garbage bag before you drop it. Splatter is contained......
Dick M is offline   Reply With Quote
Old 12-05-2018, 03:38 PM   #19
100IH
Baseball bat or wood 2x3 by far easiest and safest and fast. Because it not only pulls up on baffle but pushes out on side of oil pan, releasing the lock in the grooves.
100IH is offline   Reply With Quote
Old 12-05-2018, 09:01 PM   #20
KGBnut
KGBnut's Avatar
That is a clever idea. I've always done it with a board and a big C-Clamp. It allows me to crank it out slowly and gently....no oil splatter...no dents...
Nice to know that there are lots of ways to do it.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
