02-09-2021, 05:15 PM | #21 |
Re: Fatigue Cracks In Model "A" Parts
Who hasn't seen a cracked front cross member?
02-10-2021, 12:00 PM | #22 | |
My '31 has a couple of small cracks in the flywheel housing. Looking at them, I did not think they would ever become a problem, however I did order an un-cracked replacement housing should I ever pull the engine again. I wonder if such small cracks have ever resulted in any kind of actual running failure? I also had the radiator fill tube separation as noted earlier...an easy solder fix. 90+ years and still going...better than me, LOL... |
02-10-2021, 12:25 PM | #23 |
Where the radiator intake connects to the top tank is a frequent fatigue failure. The upper hose is very stiff and as the engine moves, especially with float-a-motors, it put high stress into that joint. We have had several of these in our club.
02-10-2021, 12:43 PM | #24 |
Funny you should ask. This just happened this week. I have never seen a water-pump casting that broke because of a too tight fan belt before tjis one.
Bob |
02-10-2021, 01:37 PM | #25 |
Steering column to gas tank bracket.
Dave / Lincoln Nebraska |
02-10-2021, 01:57 PM | #26 |
02-11-2021, 08:30 AM | #27 |
Thanks all for your replies.
Bob Bidonde |
02-11-2021, 09:23 AM | #28 |
Pictures of fatigue cracks accumulated so far:
Bob Bidonde |
02-11-2021, 03:16 PM | #29 |
Thanks for posting that. I was going to.
02-11-2021, 03:56 PM | #30 |
This is a pretty short list of parts considering the age and technology available for the time.
I like the broken gear, I have one from a Honda motorcycle where the tooth is broken on both sides and wiggles like a 3 year old's loose tooth. It came out of a running motor/trans in a kart, still together.
As Carroll Smith wrote; All Failures are Human in Origin. |
