06-25-2014, 10:21 AM | #1 |
Carburetors , modules, switches !!!
City:
miami
State:
fl
$100 each core! Will make a deal for bulk purchase!!! 1-1960's 1904 Holley 1 barrel 2- Holley 2 barrel 6r-1258-3 3-Rockester GM Quadrajet electric choke 4 barrel 7058230 0463 4-Holley 4 barrel eck-9510-h-list-1074 5-Motorcraft 2 barrel electric choke 7u apa 6-WORKING 1963 1 barrel Falcon Autolite c30 f b a2md 7-Holley 2 barrel electric choke list-6221-2 3166 8-GOOD 1965 Autolite Ford 2 barrel c52fha5ab 9-Quadrajet 4 barrel 10-GOOD but missing float 1960 Ford Autolite 2 barrel 11- 1982 v6 Motorcraft F2-2150 (Jeep/AMC/Eagle/Pacer) with electric choke PAC2 e2be va Standard Plus ss-581 Starter switch $20 Delco A/C relay #15-844 1966-67-68-69-70-71-72 CAMARO SS NOVA Z28 CHEVELLE 442 GS A/C FAN RELAY $15 Standard ps-60 Oil pressure switch $13 Standard ds-70 Dimer switch $12 Motorcraft db-187-1 $25 Standard dr-318 $1471-72 Pontiac Thermostat housing water cooler neck $25 77-79 Cadillac rear trunk logo #1716264 $109 Standard RV-10 Ballast Resistor $10 AC Delco 15-2147 A/C cutoff switch $17 Motorcraft ce-106 (5 of these) $18 77-79 Ford 30-132 Choke pull off $15 Anco 62-01 Windshield washer pump $17 Ford d5uz-4255-a $19.99 Holley GM Float 216-2 $7 Standard dr-318 Rotor $12 Standard fd 8006 $12.75 Onan 166-0820 $88 Wizard voltage regulator $65 ECCO Back up alarm 510 $26 Ford Power window gear kit $17.50 Standard vr-166 Voltage $24.99 BAC A LARM model 230 $18.50 Ford e8vy-1130-c center cap $115 Ball and roller LM-104949 $12 Everco no.a8622 $11 Borg Warner r-295 $46 Phoenix Gold Battery isolator $200 |
