Old 12-09-2022, 03:41 PM   #1
aermotor
Default charging problem
Car was running fine with normal ammeter readings - new battery. Now after starting the ammeter is normal for about five seconds then drops to -20. No other parts were changed. There is power from the J box to the generator cut out. Car sat without driving for about 1 week. What could be wrong?
aermotor is offline   Reply With Quote
Old 12-09-2022, 03:57 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: charging problem
What is the voltage?
Old 12-09-2022, 04:46 PM   #3
Patrick L.
Patrick L.'s Avatar
Not enough info. 6v or 12v ? Generator or alternator ?
Old 12-09-2022, 05:04 PM   #4
aermotor
6 volt generator
Old 12-09-2022, 05:22 PM   #5
aermotor
There is stupid questions. How do I check voltage?
Old 12-09-2022, 08:05 PM   #6
midgetracer
midgetracer's Avatar
is the polarity on the battery hooked up correct. That is positive ground.
midgetracer is offline   Reply With Quote
Old 12-09-2022, 10:43 PM   #7
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Go buy a cheap volt ohm meter.
Old 12-13-2022, 04:50 PM   #8
aermotor
Yes, it is correct. I think my problem is upstream from the battery and generator. As soon as I turn the key on the amp gage sits at 0 for a second
and then goes to -15. Head lights and horn are disconnected. Can't get a good amp or voltage reading when this happens - battery showing 6.5 volts.
Old 12-14-2022, 09:37 AM   #9
Badpuppy
Post #1 says engine running. #8 implies engine off. Main suspect is ammeter post has pushed through paint on tank wall.
