Old 01-29-2021, 11:10 PM   #1
Lawrie
Lawrie's Avatar
Default French rods
Any one know where to get these from ,
Lawrie
Old 01-29-2021, 11:26 PM   #2
Kilohertz
Kilohertz's Avatar
Default Re: French rods
Lawrie
I'd love to find a French flathead...what do you have?
cheers
1949 Ford F-47 with a '51 8BA Flatty, GM TBI fuel injection system, and a grey shop cat, Spot.
Kilohertz is offline   Reply With Quote
Old 01-29-2021, 11:33 PM   #3
Brian
Brian's Avatar
lawrie, Can't directly answer your question, but of course you know they come in two lengths? 7 inch and 6 7/8". Which ones you want?
Old 01-30-2021, 02:11 AM   #4
Lawrie
Lawrie's Avatar
Brian, I think 7in ,as its for a 99A block,
Lawrie
Old 01-30-2021, 04:42 AM   #5
Mart
Mart's Avatar
If you want 7" rods, they are the same as 8BA. Only the 6-7/8" rods are unique to the French motors.
For 3-3/4" cranks you use the 7" rods. for 4" cranks you use the 6-7/8" rods. This allows the french motors to use the same pistons.
A ford piston will need modifying to clear the 4" crank as the skirts hit the crank at the bottom of the stroke.
Mart.
Old 01-30-2021, 05:31 AM   #6
Tim Ayers
SoCal Sacramento still has them. They’ve gone in price a bit but still a good deal.
http://vxgrf.crzvw.servertrust.com/S...flat001020.htm
Old 01-30-2021, 02:40 PM   #7
swanwaco32
Good Luck with So Cal they appear to be closed??
swanwaco32 is offline   Reply With Quote
Old 01-30-2021, 09:45 PM   #8
51504bat
51504bat's Avatar
Web site is up and running and they still list the rods.
Old 01-30-2021, 10:15 PM   #9
Bob C
Website says they are open Sat-Sun 12:00-8:00 PM closed M-F
Old 01-31-2021, 11:15 AM   #10
rotorwrench
rotorwrench's Avatar
Reconditioned 8BA rods will likely be less expensive. If you have a way to get them reconditioned near you then they will be even less expensive as used parts.
Old 02-01-2021, 11:05 AM   #11
51504bat
51504bat's Avatar
I'm no flathead guru or machinist but the very flathead experienced machinist who did the machine work and assembled my 8ba short block told me that reconditioning flathead rods wasn't like more modern rods. He said the end result wasn't the same as a new rod. Don't know the why's, etc and I have no reason to believe he was blowing smoke. Why would he turn down a chance to make the additional money to resize the rods unless there was a valid reason not to resize them? Based on his advice I went with the new rods from SoCal. I do know my engine runs great.
Old 02-01-2021, 12:19 PM   #12
Tim Ayers
I bought my set when they are where $130 bucks, so it was no brainer. The price has since gone up quite a bit.
Old 02-01-2021, 05:02 PM   #13
rotorwrench
Most of a recondition job is cleaning, inspecting, and replacement of the small end bearings. The replacement of the small end bearings and how they are sized would be the only difference I can think of unless the big end has fretting or some other problem. If done as original then they will be as good as original.
Old 02-01-2021, 06:18 PM   #14
tubman
tubman's Avatar
I agree with this. I have been saving rods (8BA style) for the last 30 years. When I had the basic machine work done on the engine, I brought in about 20 rods. The machinist did the cleaning and inspecting, and easily found 8 rods that were OK as is.
