Old 01-14-2020, 02:33 PM   #1
zorro4153
Default 1935 Open Car Radio
Hi,
I'm installing the radio box and speaker in a 35 phaeton and are not sure of placement. Does anyone have any picture of them installed ?
Thanks,
Tony
zorro4153 is offline   Reply With Quote
Old 01-14-2020, 03:26 PM   #2
Don Rogers
Don Rogers's Avatar
Default Re: 1935 Open Car Radio
Tony, There should be some dimples on your firewall where the mounting hole should be drilled. I am including pictures of where these dimples are located as well as an image from the radio installation manual showing the approx location of of the radio between the steering column and the inside firewall. I also included the correct mounting hardware.
Don Rogers is offline   Reply With Quote
Old 01-14-2020, 04:13 PM   #3
VeryTangled
VeryTangled's Avatar
More on the bolts, it came up recently...
https://www.fordbarn.com/forum/showt...ighlight=radio
-Jeff H
Old 01-14-2020, 09:00 PM   #4
zorro4153
Don and Jeff, thank you very much for the info.
Tony
Old 01-14-2020, 10:39 PM   #5
Bruce/CT
Hi Don,
Does your photo/ diagram above apply to a 1936 Open car also? or are they different?Thanks, Bruce
Failure is simply the opportunity to begin again, this time more intelligently.......Henry Ford
Bruce/CT is offline   Reply With Quote
Old 01-14-2020, 11:25 PM   #6
Don Rogers
Don Rogers's Avatar
Bruce, If you have an open 36 then it does.
