11-27-2016, 07:26 AM | #1 |
Rear Axle Venting
One thing I've noticed on these Ford rear axles is they are not vented. Model T to 1948.
All later makes to today vent the rear axles. Did all these earlier Ford axles vent in a way I'm not seeing? |
11-27-2016, 09:45 AM | #2 |
Re: Rear Axle Venting
The venting process is through the torque tube via the transmission.
11-27-2016, 10:21 AM | #3 |
You know I thought that at first but then there is a seal within the torque tube up by the drive shaft bearing/ speedo drive gear.
11-27-2016, 10:27 AM | #4 |
Does my 52 have a vent in the diff.? I just can't recall seeing one.
https://www.youtube.com/user/roosty6/videos |
11-27-2016, 10:49 AM | #5 |
It vents thru the hollow bolt that holds the brake line 'T' fitting to the axle housing.
11-27-2016, 02:21 PM | #6 |
11-27-2016, 10:58 AM | #7 |
As stated, the torque tube rear axles have a much larger volume that allows more expansion than the later axles. When you convert a torque tube axle to an open drive it is a good idea to add a vent. I run a quick change and you really need the vent added to allow a pressure release as the gears heat up. Without a vent the axles tend to force gear lube past the axle seals and into/onto the brake drums.
11-27-2016, 11:30 AM | #8 |
When I installed a Mitchell in our 46 I had to add a rear end vent in addition to the vent that comes with the Mitchell..
11-27-2016, 01:05 PM | #9 |
I've been pondering this exact topic recently. I was changing the rear axle gear lube in my 1.5 ton truck and noticed a venting of pressure when I removed the fill plug. The axle was at room temp (not warm from driving) when I did this. Does anyone make a vented fill plug for these bigger truck axles?
11-27-2016, 04:12 PM | #10 | |
'52 F-1, EAB flathead |
11-27-2016, 05:09 PM | #11 |
I put a vent in the (closed) drive shaft housing. Close to middle.
I had tried to put a vent using the fill plug, and also at the side of one of the bells, using a drilled bolt. All of these trials failed- oil came out. I drilled the tube put a fitting and a small fuel filter on that. Karl |
11-27-2016, 05:36 PM | #12 |
As Karl said, stay away from the center-section, it will throw oil out. Top of the axle housing is where I would put the vent. Run a tube (rubber hose) from the vent fitting to the height of the frame and then "J" it over. You don't want to pick up any water with the vent tube!
11-27-2016, 08:48 PM | #13 |
So all those years Ford didn't have one?
It didn't vent out some place...... Interesting. |
11-27-2016, 11:26 PM | #14 |
I vented the driver side 36 bell in my avatar right wherexan 8 or 9" rear would be vented before I installed the open drive 3:54 center section using a vent from a 8 or 9" rear. I also drain the rear in my car every winter with all of the driving I do with it. Usually a 85-120 or so rear fluid works great for me ...
