01-25-2013, 11:26 AM | #1 |
tillotson carburetor stripped inlet
Has anyone repaired a stripped inlet on a tillotson carburetor?
01-25-2013, 01:07 PM | #2 |
Re: tillotson carburetor stripped inlet
pm sent. bob
01-25-2013, 01:35 PM | #3 |
I epoxied an appropriate brass fitting to mine when stripped. Worked fine.
01-25-2013, 09:01 PM | #4 |
Before you spend a lot of time on it, check to see if the bottom fits flat to the top and where it mounts to the intake is flat.
01-26-2013, 08:21 AM | #5 |
01-26-2013, 10:44 AM | #6 |
01-26-2013, 05:21 PM | #7 |
01-28-2013, 07:45 PM | #8 |
has anyone successfully used a helicoil in the inlet?
01-29-2013, 07:08 AM | #9 |
FWIW, I mis-read what was being repaired. I thought it was a manifold flange tapped hole. The gas inlet compression fitting may not have a helicoil available for the diameter and thread pitch.
