Old 04-21-2021, 10:38 AM   #1
russcc
Default What are these adapters for ?
I have some of these adapters and it looks like they adapt some type of brake backing plate to some type spindle. Any ideas. Thank you.
russcc is offline   Reply With Quote
Old 04-21-2021, 11:43 AM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: What are these adapters for ?
Man, those are more rare than teeth on a chicken. Pictured below are '42-'48 LINCOLN FRONT backing plates. If you'll look closely, the offset (deep stamping) of the part where the four bolt holes are located is about 1/2" DEEPER than a Ford Lockheed backing plate. If you bolt them to a Ford spindle AS-IS, the brake shoes will be partially visible between the backing plate and the brake drum. Those spacers will bring the '42-'48 FRONTS back into the same plane as stock Ford, or even Lincoln REAR backing plates.
As a side note, ALL Lincoln REAR backing plates have the same offset as Ford Lockheed plates, and the Lincoln REAR plates can be used AS-IS (NO spacer) on the front, '37-'48 Ford spindles. 1941 ONLY Lincoln FRONT plates can be bolted-on to '37-'48 Ford spindles AS-IS....NO mods! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-21-2021, 01:34 PM   #3
Brian
Brian's Avatar
And pictured is a spacer required to fit 39-40 Lincoln front b/plates to 35-36 spindles, again to correctly position the 35-36 brake drums.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 04-21-2021, 06:05 PM   #4
russcc
Thank you for your responses. I thought it might be for something like that.
Old 04-21-2021, 08:01 PM   #5
McMimmcs
McMimmcs's Avatar
I love it when people say “ I thought so” ! Hahaha
McMimmcs is offline   Reply With Quote
Old 04-21-2021, 08:15 PM   #6
Tinker
Tinker's Avatar
Originally Posted by V8COOPMAN View Post
. Man, those are more rare than teeth on a chicken. DD ....
You mean hens tooth? Just messing.
Great info as usual from you, a wealth of info.
Old 04-21-2021, 09:05 PM   #7
19Fordy
19Fordy's Avatar
V8, Thanks for posting. I learned something new from you today. Jim
19Fordy is online now   Reply With Quote
Old 05-28-2021, 06:10 PM   #8
Early Ford Junkie
Early Ford Junkie's Avatar
learn something everytime I'm on here great thread
Early Ford Junkie is offline   Reply With Quote
Old 05-30-2021, 10:26 AM   #9
scicala
scicala's Avatar
I love it when people make comments that don't help anything.
Sal
Old 05-30-2021, 10:46 AM   #10
Tim Ayers
Retracted
Old 05-30-2021, 10:50 AM   #11
JM 35 Sedan
JM 35 Sedan's Avatar
Sal
Yep, I love it too! Just like this comment I'm making now, but it does add to our total post count numbers which some here really like to do.....
John
Old 05-30-2021, 01:06 PM   #12
ford38v8
ford38v8's Avatar
Chicken lips are harder to find than hen’s teeth.
Alan
Old 05-30-2021, 09:23 PM   #13
Tinker
Tinker's Avatar
Depends on what you are looking for and your mojo.
Old 05-30-2021, 09:59 PM   #14
GB SISSON
GB SISSON's Avatar
I didn't know chickens had lips and what's a post count?
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 05-30-2021, 10:02 PM   #15
Tinker
Tinker's Avatar
GB, post counts are something we all value and really respect. It's why we are here. Irony is implied.
I live in northern mn, good hens lips are hard to find, plenty of hens teeth though. Yikes!!!
But we digress.
Old 06-01-2021, 03:26 PM   #16
GSCOV
Thought they were muffler bearing races.
GSCOV is offline   Reply With Quote
Thread Tools
Display Modes
