08-27-2020, 01:34 PM | #1 |
Attempt two at a sacrificial anode
Well, after a long discussion with my partner and a little foray into electrolysis. I have come to the conclusion that my original idea for a sacrificial anode is bad execution of a good idea. In short, the whole thing works by electrolysis, which requires continuity. A chain makes a very poor conductor of electricity and the use of one in this instance, while looking fancy, is a bad idea.
Essentially what I did was replace the chain with a length of 12 gauge stranded wire, soldered to the radiator cap and attached firmly to the anode with a #10 screw. I checked the whole thing out with an ohmmeter, and there is minimal resistance from one end to the other. Hopefully, this will provide a path for the electrons to do their dirty work on the chunk of magnesium instead of my nice aluminum heads. I got the idea for the chain from a nice looking zinc fish hanging on a chain that someone was selling. I thought it looked real good. As one of the long time H.A.M.B. members says : “In any conflict between Physics and Style, Physics always wins”. |
08-27-2020, 02:39 PM | #2 |
Re: Attempt two at a sacrificial anode
In the maritime industry, it's pretty common to electrify the hull of ships to prevent corrosion.
08-27-2020, 06:15 PM | #3 |
You might consider a washer and nut on the end of that #10 screw. As the anode melts way, the threads in the anode may also melt.
Alan |
08-27-2020, 08:42 PM | #4 |
08-28-2020, 08:38 PM | #5 |
Google "pencil zinc anode".
Tom |
08-29-2020, 01:59 AM | #6 |
GM Pencil Zinc Anode W/Brass Plug - 450-02001T
08-29-2020, 04:18 AM | #7 |
Genuine 'pencil zinc anode'
08-29-2020, 07:12 AM | #8 |
That's what I was originally considering, but there are no extra openings on the Edmunds heads. Plus I'd like one in each side, since they're kinda small.
08-29-2020, 11:18 AM | #9 |
Here's another interesting Fordbarn discussion about sacrificial anodes.
https://www.fordbarn.com/forum/showt...t=anode&page=2 |
