04-13-2020, 02:48 AM | #1 |
Freeing up a frozen 36 speedometer
Hi , we have a couple of 36 speedometers, one with a somewhat rusty body and faded face and numbers they seems to function well . The one we want to use has a nice body and nice face ( don’t we all want that) but after 24 hrs with penetrating oil in the cable input end it still won’t budge. Am I looking at the wrong place for frozen?.
04-13-2020, 03:05 AM | #2 |
Re: Freeing up a frozen 36 speedometer
There are 3 different types.Waltham,Delco and SW.The parts do not interchange.Is your bezel a push on or crimped on style?You need to remove the bezel,then the needle(maybe).The needle is that hardest to get off without damage as its on a tapered shaft.The screws on the back come off and the unit drops out for access to the mechanism.
04-13-2020, 05:27 AM | #3 |
There is usually a small oil cup take the plug out of the hole and add some light oil.
04-13-2020, 04:01 PM | #4 |
I took the mechanism out of the case and soaked in penetrating oil where cable goes in but still no luck. It is a delco speedometer. Some say there is a Welch plug near where cable goes in , Found the little brass plug further down than I thought , removed it and the felt. Will wait and see.
04-13-2020, 07:03 PM | #5 |
Warm it up with a propane torch while trying to turn it. I’ve had pretty good luck freeing up some using heat.
04-13-2020, 10:35 PM | #6 |
04-13-2020, 10:48 PM | #7 |
Heating it up might be just a temporally fix. Once it congeals again it might stick again. Might. Maybe a shot of brake cleaner and flush. Then re-oil. Lithium grease.
04-14-2020, 04:06 AM | #8 |
Yup, did the brake cleaner thing too, then some degreaser , and lubed it. tested it on the bench with an electronic speed sensor to cable adapter , powered the adapter up , flipped all the switches and it read 60mph for 20 seconds and the odo read 3/10 more as Its supposed to .. So here’s hoping .
