Old 11-14-2019, 01:30 AM   #1
my4dv8
Default 32 B4 rear seal missing
We sent our bare 32 B4 block in for crack examination and dip stripping to an engine restoration shop . the guy forgot to remove the aluminium seal thing (what is the correct name) So where do we start looking for the now dissolved part?
The block was not the best as it had been previously sleeved , and the deck surface was somewhat pitted . We plan to do an OHV conversion . But these blocks are getting harder to find . Better would be nicer. Was told on initial inspection it was crack free.
File Type: jpg B14365FD-38AC-4810-8873-EF0717873C30.jpg (44.0 KB, 68 views)
my4dv8 is offline   Reply With Quote
Old 11-14-2019, 08:23 AM   #2
Dave in MN
Dave in MN's Avatar
Default Re: 32 B4 rear seal missing
For a good reproduction of the original: Snyder's has them in their offerings: Rear main oil seal B-6335
Another option that I most often use on a B block is the Small Block Chevy (SBC) rear seal modification. Dan McEachern, from California, makes a SBC seal holder that is machined with the block to accurately align it. If you plan to up the oil pressure to the mains, this system will help eliminate leaks. I have used about 8 of the kits in the past 12 years. Order the kit before you send your crankshaft out for grinding as the instructions included with the kit provide the details for the crankshaft grinder.
Dan McEachern
920 Pearl Street
Alameda CA 94501
510-532-8228
Good luck with your project.
Good Day!
Dave in MN is offline   Reply With Quote
Old 11-14-2019, 09:37 AM   #3
rotorwrench
rotorwrench's Avatar
Some folks don't think about the babbitt when tanking an A or B block. If it's going to be repoured then it's not an issue but if a person thought it serviceable then they get a surprise expense. The oil pans with a dip stick boss on V8s have to find a new boss.
Old 11-14-2019, 12:12 PM   #4
Jim Brierley
Dan McEarchern, [email protected] or phone #510-532-8228
Jim Brierley is offline   Reply With Quote
Old 11-14-2019, 01:27 PM   #5
quickchange
quickchange's Avatar
You talking the alloy slinger , have them in stock here, There is no seal there,
quickchange is offline   Reply With Quote
