Old 04-17-2018, 09:17 AM   #1
tombia
tombia's Avatar
Default model a /c4 automatic
What experience has anyone here had with this combination.
tombia is offline   Reply With Quote
Old 04-17-2018, 10:17 AM   #2
Charlie Stephens
Default Re: model a /c4 automatic
Use the "search" function and you will find a lot of information. If it is being done for medical reasons people are generally 100% in favor of doing it. Other reasons don't get much support. If I had a need I would use a modern 4 cylinder engine that came with the modern transmission.
Charlie Stephens
Old 04-17-2018, 11:06 AM   #3
tombia
tombia's Avatar
thanks, I was going to use a pinto 2.0, but it ain't the same as a banger, but at 79 I need to go to a automatic in current project.
Old 04-17-2018, 11:40 AM   #4
Charlie Stephens
Try going to the "Hot Rods and Customs Forum". It will take you to another site. Do some searches on that site. You will probably find more there on what you are trying to do. Here is a direct link to their forum section: https://www.jalopyjournal.com/forum/...ssage-board.5/
I have a '32 roadster with a Chevy II engine but its is hooked up to the early Ford transmission. I put it in 40 years ago because at that time I couldn't find any shop to do a good job rebuilding the original engine. If I was doing it today I would use an original engine with a little speed equipment.
Charlie Stephens
Old 04-17-2018, 12:55 PM   #5
CHuDWah
CHuDWah's Avatar
If I was going to do that, I'd use the 2.3 or 2.5 which are bored and stroked versions of the 2.0 - higher HP and potential for upgrading to even more. I think a C4 will fit them - if not, I'm sure adapters are available.
CHuDWah is offline   Reply With Quote
Old 04-17-2018, 01:29 PM   #6
tombia
tombia's Avatar
Charlie Stephens
What??? A Chevrolet in a Ford. Acually I would love a Chevy 11 engine from the early 1960's. Being nostslgic.
Old 04-17-2018, 02:25 PM   #7
CarlG
CarlG's Avatar
If you do use a Pinto engine, just use a stock Model A muffler, and it will sound almost the same as a Model A engine.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 04-17-2018, 03:53 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
Can't help you with a C-4, but check Bendtsen's for a GM 700R4 adaptor (among others). I bet that 4 speed O/D auto would work pretty nice.
http://www.transmissionadapters.com/Model%20A.htm
Old 04-17-2018, 04:28 PM   #9
duke36
I had a '31 with a 2000 pinto mated to a stock A tranny and muffler. Not a good combo because the pinto rev's too high for easy shifting without snychromesh. The prior owner/ installer should have used the pinto manual or automatic. Now someone else has that car.
duke36 is offline   Reply With Quote
Old 04-19-2018, 10:30 PM   #10
50B
I have a Chev 11 in my wife's Vicky And the Chev TH350 has the same bolt pattern as the Chevv with a small mod to the center cross member for clearance of the TH350
50B is offline   Reply With Quote
Old 04-19-2018, 10:37 PM   #11
50B
Originally Posted by 50B View Post
I have a Chev 11 in my wife's Vicky And the Chev TH350 has the same bolt pattern as the Chev 11 with a small mod to the center cross member for clearance of the TH350
oops I meant same bolt as the Chev 11
Old 04-20-2018, 08:27 AM   #12
JohnLaVoy
JohnLaVoy's Avatar
We used an A4LD out of a Ford Ranger Pick Up, has an overdrive and is working really well for us.
JohnLaVoy is offline   Reply With Quote
Old 04-20-2018, 10:52 AM   #13
Ruth
John, who makes the adaptor for that trans?
Old 04-20-2018, 11:45 AM   #14
Jim Brierley
I would stay with the Model A engine, the others do not have much torque. However, I do have a 180 CID Chevy commercial engine that I would willingly part with. It is like a Chevy-2 but with a 4" bore, and more torque.
Jim Brierley is offline   Reply With Quote
Old 04-21-2018, 07:57 AM   #15
V4F
V4F's Avatar
check on how much hp it takes to run the c-4 . ive seen the in hopped up bangers & they seem to work very well .
V4f
V4F is offline   Reply With Quote
Old 04-21-2018, 09:10 AM   #16
JohnLaVoy
JohnLaVoy's Avatar
A company called Speed Gems out of Michigan I believe. They have a website, they put together a complete kit.
Old 04-21-2018, 09:10 PM   #17
CarlG
CarlG's Avatar
They don't show this particular adapter on their website, but lots of adapters for chevy transmissions. They do say "ask for what you want".
Alaskan A's
Old 04-21-2018, 10:32 PM   #18
denniskliesen
denniskliesen's Avatar
With all the adapters he has listed, I doubt he has much time to piddle around with a website. Best to give him a call and ask.
denniskliesen is offline   Reply With Quote
Old 04-21-2018, 10:48 PM   #19
Y-Blockhead
Yes, that's Bendtsen's that I mentioned back in post #8. They have all kinds of adaptors.
Old 04-23-2018, 12:23 PM   #20
CarlG
CarlG's Avatar
I contacted the guys at transmissionadapters.com
Carl,
On our website you will find installation instructions for the Model A to Chev automatic installation. I direct you to that as the instructions are very similar and will give you an idea of the steps required. There is a kit available for the Model A to A4LD and it retails for $1495.
Gary
Alaskan A's
