05-25-2015, 09:10 PM | #1 |
Best plugs..??
What do most of you feel are the "Best Plugs" for a stock Model A..??
05-25-2015, 09:20 PM | #2 |
Re: Best plugs..??
Depends how you drive. I Use 3x repos.
www.whidbeymodelaclub.com |
05-25-2015, 09:28 PM | #3 |
Re: Best plugs..??
I use 3x Champions, gapped .025 with a 5.9 brumfield head, & .100 overbore
05-25-2015, 09:32 PM | #4 |
Re: Best plugs..??
me to
05-25-2015, 09:45 PM | #5 |
Re: Best plugs..??
It depends on what you are going for. In my barn find Tudor, I have the original plugs (champions) that work just fine. In my truck, I have new champion "go plugs". In my tractor, I run the standard fomoco plugs for a's. All seem happy.
05-25-2015, 10:03 PM | #6 |
Re: Best plugs..??
I use the 16y's. The work, cheap, and look beefier then the autolites. Are they better then the autolites, no. I just like the looks of them.
05-25-2015, 10:34 PM | #7 |
Re: Best plugs..??
Re-pop 3x champion seem to chew their way through pretty good. Got them as a gift, an expensive gift.
05-26-2015, 05:21 AM | #8 |
Re: Best plugs..??
CLEAN PLUGS is always best.
05-26-2015, 05:28 AM | #9 |
Re: Best plugs..??
05-26-2015, 05:52 AM | #10 |
Re: Best plugs..??
I use 3X's in all my A's. Wayne
05-26-2015, 08:19 AM | #11 |
Re: Best plugs..??
I use champion W-18 in my stock A, NAPA @ $9 each, have used them for many years and perform well with the stop and go driving here....
05-26-2015, 10:11 AM | #12 | |
Re: Best plugs..??
Now you can tell everyone you have "Racing Plugs" in your Model A. |
05-26-2015, 10:29 AM | #13 |
Re: Best plugs..??
W-18
But only if: • you use 15/40 Rotella • you have blackwall tires • you have a 160° Thermostat • you have a 12v alternator • and an overdrive • A/C is optional
05-26-2015, 10:48 AM | #14 |
Re: Best plugs..??
The O'Reilly description stated a plug gap of 0.033" to 0.038". What do you use for Model A's? Isn't .018 to .022 recommended?
05-26-2015, 10:54 AM | #15 |
Re: Best plugs..??
Please disregard my earlier post, obviously I was thinking of points. However I am interested in what you use for spark plug gap if you run a high compression head.
05-26-2015, 10:56 AM | #16 |
Re: Best plugs..??
Will these work with juice brakes?
Blackwall Panthers Nor Cal chapter |
05-26-2015, 11:16 AM | #17 | |
Re: Best plugs..??
On racin' plugs: I bought me sum RACIN' SHOES & sum RUNNIN' SHOES, neither made me FASTER Bill W.
05-26-2015, 12:05 PM | #18 |
Re: Best plugs..??
Haven't tried it, but probably not.
05-26-2015, 01:23 PM | #19 |
Re: Best plugs..??
I have the best free spark plugs-- 3X, got 2 sets from the trash at Hershey, lifetime supply , I run the car lean enough to burn black fouled plugs clean and white
05-26-2015, 02:29 PM | #20 |
Re: Best plugs..??
A good stock coil should fire the plugs fine with .035" gap, but many will cut back to .025" to .030" just because the higher compression takes more voltage to jump the same gap. The wider the gap, the harder the coil has to work, but it will more easily fire a lean mixture with the wider gap. I've never had any spark miss by using .035" on my stock head, and I'll probably try .030" gap on my 5.5 head when I install it.
