04-09-2019, 08:01 PM | #21 | |
Re: 39 shift tower, 32 case emergency brake adapter bracket
04-09-2019, 11:29 PM | #22 | |
If you look at the two shifter holes you can see the difference of where they are located on a '32 trans and a '39 trans. I don't remember which is which? I had bought an original '32 plate and then discovered it did not fit over my '39 trans. I'm not cutting up an original, I would have to go to therapy if I did that. https://www.hemmings.com/parts/item/...ped/16163.html |
04-10-2019, 08:41 AM | #23 |
The one on the left in the Hemmings photo is for '36 and up shift lever housings. The one on the right in the photo is the stock mid-to-late '32 version.
