Old 05-25-2015, 09:10 PM   #1
bobpo1
bobpo1's Avatar
Default Best plugs..??
What do most of you feel are the "Best Plugs" for a stock Model A..??
bobpo1 is offline   Reply With Quote
Old 05-25-2015, 09:20 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Best plugs..??
Depends how you drive. I Use 3x repos.
www.whidbeymodelaclub.com
Old 05-25-2015, 09:28 PM   #3
J Franklin
J Franklin's Avatar
I use 3x Champions, gapped .025 with a 5.9 brumfield head, & .100 overbore
J Franklin is online now   Reply With Quote
Old 05-25-2015, 09:32 PM   #4
Mitch//pa
me to
Old 05-25-2015, 09:45 PM   #5
30aadoodlebug
30aadoodlebug's Avatar
It depends on what you are going for. In my barn find Tudor, I have the original plugs (champions) that work just fine. In my truck, I have new champion "go plugs". In my tractor, I run the standard fomoco plugs for a's. All seem happy.
30aadoodlebug is offline   Reply With Quote
Old 05-25-2015, 10:03 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
I don't think you will find an universally accepted "best plug".
I use the 16y's. The work, cheap, and look beefier then the autolites. Are they better then the autolites, no. I just like the looks of them.
Old 05-25-2015, 10:34 PM   #7
George D
George D's Avatar
Re-pop 3x champion seem to chew their way through pretty good. Got them as a gift, an expensive gift.
George D is offline   Reply With Quote
Old 05-26-2015, 05:21 AM   #8
Jacksonlll
Jacksonlll's Avatar
CLEAN PLUGS is always best.
Old 05-26-2015, 05:28 AM   #9
RonC
RonC's Avatar
http://www.oreillyauto.com/site/c/de...-1&keyword=429
RonC is offline   Reply With Quote
Old 05-26-2015, 05:52 AM   #10
C26Pinelake
I use 3X's in all my A's. Wayne
C26Pinelake is offline   Reply With Quote
Old 05-26-2015, 08:19 AM   #11
JD 1931
JD 1931's Avatar
I use champion W-18 in my stock A, NAPA @ $9 each, have used them for many years and perform well with the stop and go driving here....
JD 1931 is offline   Reply With Quote
Old 05-26-2015, 10:11 AM   #12
Y-Blockhead
Y-Blockhead's Avatar
I like the discription... "Champion Racing Plugs Power More Race Cars To Victory Than Any Other Spark Plug."
Now you can tell everyone you have "Racing Plugs" in your Model A.
Old 05-26-2015, 10:29 AM   #13
CarlG
CarlG's Avatar
W-18
But only if:
• you use 15/40 Rotella
• you have blackwall tires
• you have a 160° Thermostat
• you have a 12v alternator
• and an overdrive
• A/C is optional
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-26-2015, 10:48 AM   #14
djlanier
The O'Reilly description stated a plug gap of 0.033" to 0.038". What do you use for Model A's? Isn't .018 to .022 recommended?
djlanier is offline   Reply With Quote
Old 05-26-2015, 10:54 AM   #15
djlanier
Please disregard my earlier post, obviously I was thinking of points. However I am interested in what you use for spark plug gap if you run a high compression head.
Old 05-26-2015, 10:56 AM   #16
Tiny
Tiny's Avatar
Originally Posted by CarlG View Post
W-18
But only if:
• and an overdrive
• A/C is optional
Will these work with juice brakes?
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 05-26-2015, 11:16 AM   #17
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Run whatever plug that gives you that LIGHT TAN color on the inside porcelain insulator.
On racin' plugs: I bought me sum RACIN' SHOES & sum RUNNIN' SHOES, neither made me FASTER
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 05-26-2015, 12:05 PM   #18
CarlG
CarlG's Avatar
Haven't tried it, but probably not.
Alaskan A's
Old 05-26-2015, 01:23 PM   #19
Kurt in NJ
Kurt in NJ's Avatar
I have the best free spark plugs-- 3X, got 2 sets from the trash at Hershey, lifetime supply , I run the car lean enough to burn black fouled plugs clean and white
Old 05-26-2015, 02:29 PM   #20
Tom Wesenberg
Tom Wesenberg's Avatar
A good stock coil should fire the plugs fine with .035" gap, but many will cut back to .025" to .030" just because the higher compression takes more voltage to jump the same gap. The wider the gap, the harder the coil has to work, but it will more easily fire a lean mixture with the wider gap. I've never had any spark miss by using .035" on my stock head, and I'll probably try .030" gap on my 5.5 head when I install it.
