Old 09-20-2021, 12:36 AM   #1
casper_wcx13
Default 1955 ford fairlane town sedan radiator issue.
I ordered a 3 row aluminum radiator and noticed it has ports for transmission cooler lines but the current stock radiator does not have them. Is this normal? The town sedan is an automatic.
casper_wcx13 is offline   Reply With Quote
Old 09-20-2021, 05:15 AM   #2
LOWRIDER
LOWRIDER's Avatar
Default Re: 1955 ford fairlane town sedan radiator issue.
You have an early air cooled transmission. Look for an air scoop on the right lower side of the transmission near the convertor housing.
Dan Kingman Az. 86409
LOWRIDER is offline   Reply With Quote
Old 09-20-2021, 06:20 AM   #3
casper_wcx13
Thanks ill check it out once the sun comes up. [emoji1303]
Old 09-20-2021, 04:24 PM   #4
dmsfrr
dmsfrr's Avatar
casper_wcx13,
It should look a lot like this one...
Old 09-20-2021, 07:11 PM   #5
KULTULZ
KULTULZ's Avatar
Post Re: 1955 ford fairlane town sedan radiator issue.
Use brass block-off hardware to seal the RAD TRANS COOLER.
You don't want road dirt going in there.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 09-20-2021, 06:18 AM   #6
darrell
this rad can be used on both.
darrell is offline   Reply With Quote
Old 09-20-2021, 09:52 AM   #7
delco1946
delco1946's Avatar
I recently went through this experience. I ended up getting mine recored as I read somewhere that you run the risk of rust/corrosion with this new style of radiator if you don't use the bottom portion. The thinking was that the temperature differential between the used upper portion and the unused (at least on our air cooled trannys) can cause moisture to form in the bottom reservoir, that when unused just "sits" there potentially leading to corrosion.
It's prolly not a big concern, but I didn't want to go down that road.
delco1946 is offline   Reply With Quote
Old 09-20-2021, 08:09 PM   #8
Daves55Sedan
Daves55Sedan's Avatar
Some years ago, I ordered a new radiator from Concours Parts. At that time, they offered the radiator with the transmission cooler or without.
1956 was the last year for the air-cooled converter on V8 cars. So '54/55/56 Ford V8 cars do not need the transmission cooler in the bottom radiator tank.
Another thing you gotta watch out for is the side mounting brackets. the V8 radiators have "recessed" side mount brackets. The 6-cyl cars have extended side mount brackets. You must select the proper configuration for your vehicle.
These same radiators were used in the F100 trucks but they had a different set of radiator mounting brackets. Concours sells the truck radiators too but they are listed in a separate catalog, however, they're probably physically sitting right next to the car radiators in the warehouse.
I'm almost positive they sent me a truck radiator and they sent one with the trans cooler to boot. I went back and checked my order and verified that I DID order the right radiator. They just shipped the wrong one.
I recommend NOT ordering the radiator with the trans cooler as it could cause trouble down the road from condensation and rust through.
My episode with Concours led me to BOYCOTT them ever after.
Old 09-23-2021, 12:18 AM   #9
cokefirst
Actually, 1956 was a transition year, the late 1956 Thunderbirds had the cooler lines, and the early ones did not. The 56 F100 had a complicated cooler that did not use the bottom of the radiator yet had a fitting that went into the radiator hoses. You can see it in the parts book. I am not sure if the late passenger cars had the water cooled transmission in late 1956 but I suspect that they do.
cokefirst is offline   Reply With Quote
Old 09-23-2021, 11:05 AM   #10
KULTULZ
KULTULZ's Avatar
Thumbs up Re: 1955 ford fairlane town sedan radiator issue.
You are correct. Temp changes will cause air-flow and condensation. Usually, they used to come with fittings to block the cooler off if sold as a multi-use.
- WHY IS IT ... -
