Old 09-25-2021, 07:27 AM   #1
cowtown
Default Removing Gas Tank Question
I am trying to remove my gas tank on my 29 CC Pickup and can't get a wrench on the inside of the two bolts on each side of the tank at the door post. Any idea's on what type of wrench to use?
cowtown is offline   Reply With Quote
Old 09-25-2021, 09:38 AM   #2
KenBolton
Default Re: Removing Gas Tank Question
A fire wrench will work. Then you won’t need to worry about which steel wrench to use until you put it back on.
KenBolton is offline   Reply With Quote
Old 09-25-2021, 01:49 PM   #3
Dennis Pereira
Dennis Pereira's Avatar
I hope that was a joke a torch and a gas tank is a bad mix .
Dennis in Kelsey ca
Dennis Pereira is offline   Reply With Quote
Old 09-25-2021, 03:04 PM   #4
700rpm
700rpm's Avatar
That isn’t funny.
Ray Horton, Portland, OR
Old 09-26-2021, 01:23 AM   #5
pbishop
Use penetrating oil on the whole series of bolts and fasteners and wait. Then use a 'dog bone' wrench. You may have to reverse the position and may even have to heat the wrench and bend it straighter a little if necessary.
As another member stated, flame and gas tanks do not mix well.
pbishop is offline   Reply With Quote
Old 09-26-2021, 06:40 AM   #6
McMimmcs
McMimmcs's Avatar
Originally Posted by 700rpm View Post
That isn’t funny.
X2 for sure!
McMimmcs is offline   Reply With Quote
Old 09-26-2021, 07:48 AM   #7
cowtown
Thanks Guys, I managed to get the tank removed. I heated and then bent a old wrench to get it on the nuts inside the door post.
