Old 01-16-2017, 11:59 AM   #1
1931SWA
Default Multi disc clutch
Does any out there have parts for multi disc clutch? I'm restoring a June 5th, 1928 roadster p/up. I'd like to keep it as close as possible to the way it was built. I have the correct pedals, small shaft, trans, bell housing.
1931SWA is offline   Reply With Quote
Old 01-16-2017, 12:52 PM   #2
KGBnut
KGBnut's Avatar
Default Re: Multi disc clutch
Where are you located? I have a spare transmission I might be willing to part with. It has the big castle nut on the input shaft indicating that it was from a multi-disc. I've heard that with a few modifications it can be be used with my single-disc...but, I may be better off to get one that doesn't need modifications.
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 01-16-2017, 01:29 PM   #3
Ron in Quincy
Ron in Quincy's Avatar
I have all the modified parts, AR Bell Housing, AR Transmission, AR Flywheel Cover, and cut down regular Flywheel that weights 37 pounds including ring gear. I made the same conversion on my very early Sport Coupe. When installed the conversion, from outside appearance, you would think the "A" has a multi-disc clutch.
The parts would be too heavy to ship so they would have to be picked up at my home in Northern California.
The cost for the parts is $1,025.00.
If interested, send me a PM. I have pictures I can send you of the modified parts.
Note: the Flywheel has been balanced and is tapped for a V8 pressure plate; only thing required is the pressure plate and clutch disc.
Ron in Quincy is offline   Reply With Quote
