11-18-2020, 02:50 AM | #1 |
1940 Ford clutch link
Heyall,
Can anyone share a photo of a factory 1940 Ford clutch/transmission/pedal setup on a right hand drive car? I'm doing the left to right hand drive swap here in Australia. I'm about to pop the engine and trans back in my convertible and wanting a head start on what it should look like, and identify if I'm missing any parts! Thanks in advance, Tom P1000145a.jpg |
11-18-2020, 05:11 AM | #2 |
Re: 1940 Ford clutch link
Here is a pic of my swap. Ignore the square bar chatter rod. We were mucking about with ideas.
No problems encountered . The swap of the clutch linkage in the gearbox was probably the most tedious. I got a lever arm from an Aussie box. regards Dave |
11-18-2020, 05:23 AM | #3 |
It's hard to tell from the pic, but does that clutch linkage go straight to the gearbox (39 style) or does it have a relay lever as intro'd on the LHD 40 Fords?
Mart. |
11-18-2020, 12:58 PM | #4 | |
11-18-2020, 04:39 PM | #5 | |
Yes looks like a straight shot from the pedal to the gearbox. no relay lever. needed. I asked over on Facebook and received this photo to confirm. |
11-18-2020, 04:48 PM | #6 |
Coopman, I feel like I've seen that photo before! Yes the transmission is an opposite casting of the LHD version. pretty cool! |
11-18-2020, 05:21 PM | #7 | |
11-18-2020, 05:38 PM | #8 | |
Now, like I suspected, here is a '39 Lincoln Zephyr transmission case. The bolt spacing looks to be exactly like the LEFT transmission in your picture. A Lincoln trans case it seems to be. I believe at least '38 & '39 were the same. '40 Lincoln is different. (Thanks Ken/Alabama) DD |
11-19-2020, 05:09 AM | #9 |
The pedals are not a reverse of the 39 setup, because the orientation of the clutch and brake pedals are the same regardless of hand of drive.
The RHD clutch pedal handily falls right next to the clutch release lever so if you look closely at that pic above you can see the pedal rising up above the lower part. In other words the pedal does not need to travel through the brake pivot like a LHD 39. Mart. |
11-19-2020, 04:03 PM | #10 | |
....as well as this picture of a RHD pedal set...... .....it looks like that's exactly what they did. They reversed that shaft end for end, and manufactured TWO dedicated pedals leaning toward the right. The BRAKE pedal has a lower hole bushed to shaft diameter so that it can oscillate. The CLUTCH pedal hole machined to shaft diameter and PINNED to shaft, as well as bushing the center shaft support hole in the bracket itself. That set-up would articulate all functions as necessary. DD ........ |
11-20-2020, 05:09 PM | #11 |
Good discussion.
Coopman the RHD case sure does look like that Lincoln one. I have two empty RHD cases in the shed, one is supposedly from 46, I'll see if its the same early 39 Lincoln style. Will also try to get a better shot of the pedals, although they're not very photogenic. As Mart said, the pedals are in the same order, there is no need for the shaft inside shaft arrangement. And they're specific castings for foreign (RHD) vehicles. The RHD ones in my car have 37 written on them in texta, and feature one large diameter shaft shared by both pedals. I recon I have a set of 40 ones too... (small diameter shaft) will have a look. Installed the engine and trans, to confirm and measure up the clutch pivot and rod. Straight shot, what was I worried about! |
11-20-2020, 06:52 PM | #12 | |
11-20-2020, 07:35 PM | #13 |
I believe the pedals are like a LHD 40. Captive shaft in the bracket, both pedals bushed and rotating on the shaft. There's no need for any inside/outside trickery, as the clutch pedal automatically gets a straight shot at the clutch lever.
Could be wrong, though. A picture of the individual parts would be helpful. Mart. |
11-21-2020, 04:51 PM | #14 |
Mart is on the money, the shaft is fixed to the mounting bracket. Removable but a press fit(?)
Here's some shots of my second set, these are prefixed 01A, from 1940. Smaller shaft diameter. |
11-21-2020, 06:45 PM | #15 |
Ah....Now I can see that CLUTCH pedal clevis for the actuator rod. It just didn't look like that in that "gold-ish" picture you posted above. Makes perfectly good sense NOW.....just like Mart surmised. I'd be curious to know if that pedal BRACKET has a number AFTER the "01A-" of something SIMILAR to "2467" (01A-2467)? It appears to be the 'mirror' image of an American '40-'48 LHD bracket. DD
