Old 03-25-2020, 11:18 AM   #1
Kerk
Default Cable driven Tach. info .
I am looking for Cable driven Tach. info and believe I saw it a while back. Any info is welcome. Kerk [email protected] Thanks
Kerk is offline   Reply With Quote
Old 03-25-2020, 12:31 PM   #2
whygoby
whygoby's Avatar
Default Re: Cable driven Tach. info .
Kerk, I make a reproduction model 674L S/W tach drive gearbox that doesn't require a mounting bracket, but just "floats off the front of the engine. PM me for more details!! whygoby
whygoby is offline   Reply With Quote
Old 03-25-2020, 04:55 PM   #3
solidaxle
solidaxle's Avatar
Can you be more specific.
solidaxle is offline   Reply With Quote
Old 03-25-2020, 04:57 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
PM "whygoby" for details! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-25-2020, 05:05 PM   #5
solidaxle
solidaxle's Avatar
I meant the original poster Kerk. Not sure what he is asking.
Old 03-25-2020, 05:37 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
Sorry...I blew that one! DD
T5 W/TORQUE TUBE
Old 03-26-2020, 07:50 AM   #7
solidaxle
solidaxle's Avatar
I should have been more specific on my specifying.
Old 03-26-2020, 03:55 PM   #8
whygoby
whygoby's Avatar
The reproduction Stewart Warner 674L tach drive unit doesn't require a mounting bracket, or inner flex drive link. The speedo cable that goes to the tachometer head holds the gearbox in place, so the unit just "floats". PM me for more details. Thanks, Doug
Old 03-26-2020, 09:38 PM   #9
GB SISSON
GB SISSON's Avatar
Is there something simple but not period correct for a tach? I would think some kind of magnet or sensor attached to the crank pulley could be read by a gauge on the dash with 12 volts... ??
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 03-27-2020, 01:01 AM   #10
flatheadmurre
flatheadmurre's Avatar
On 12v you should be able to take the signal from the coil with just about any tach as gauge...or are we talking the worlds first dieselpowered flathead
Old 03-28-2020, 05:39 PM   #11
whygoby
whygoby's Avatar
Here is the new 674L tach drive gearbox that just "floats", and doesn't require a mounting bracket. PM me if you want more info. This gearbox shows up in the 1942 Stewart Warner master catalog.
Old 03-28-2020, 08:55 PM   #12
GB SISSON
GB SISSON's Avatar
You got the diesel powered part right. No coil and the engine manufacturer no longer sells a tach drive for this model. 99 percent of the rest of the truck is still 47 ford. I can google it. I DO like that floating tach drive for my proper flathead powered vehicles.
Old 03-29-2020, 03:10 PM   #13
flatheadmurre
With some luck your alternator has the W connection itīs for tach drive.
Lots of the big trucks has this.
If you donīt have it open up the alternator install a wire to one of the stator windings where they attach to the rectifier and there you have you tachdrive signal.
Last edited by flatheadmurre; 03-29-2020 at 03:17 PM. Reason: Added info for taking out tach signal
