Old 08-21-2019, 11:37 AM   #1
Digger
Digger's Avatar
Default Where do I buy those stock 33-34 valve stems?
Going to blackwall and black rims and can’t recall where to buy those tall stock looking valve stems... any suggestions? Thanks.
Digger is offline   Reply With Quote
Old 08-21-2019, 11:53 AM   #2
DavidG
DavidG's Avatar
Default Re: Where do I buy those stock 33-34 valve stems?
If you mean the original nickel-plated valve stems as shown below, you can buy excellent reproductions from A & L Parts Specialties in Canton, CT. or you can buy inner tubes with those stems already installed in the tubes from Coker Tire, Lucas, Universal, etc. You still would need to purchase the bridge washers (the washer with wings), bridge washer retaining nuts, and outer valve stem retainers separately from A & L. (The bridge washers that they offer are for Model A rims and the corners must be trimmed to fit properly in '32-'34 rims. I don't know of anyone offering the correct bridge washers for the '32-'34 rims.)
Old 08-21-2019, 10:07 PM   #3
Digger
Digger's Avatar
Perfect, thank you so much.
Old 08-21-2019, 11:14 PM   #4
DavidG
DavidG's Avatar
You're welcome!
Old 08-22-2019, 05:14 PM   #5
mercman from oz
mercman from oz's Avatar
Great picture of these original style Valve Stems.
Old 08-22-2019, 05:55 PM   #6
Scott/Mn
Scott/Mn's Avatar
http://sheepisland.com/cars/tech/metal_stems/
Scott/Mn is offline   Reply With Quote
Old 08-23-2019, 07:22 AM   #7
GaryU.
GaryU.'s Avatar
Thank you Scott/Mn for posting the instructions, learned something new this morning.
GaryU. is offline   Reply With Quote
