03-25-2020, 11:18 AM | #1 |
Cable driven Tach. info .
I am looking for Cable driven Tach. info and believe I saw it a while back. Any info is welcome. Kerk [email protected] Thanks
03-25-2020, 12:31 PM | #2 |
Re: Cable driven Tach. info .
Kerk, I make a reproduction model 674L S/W tach drive gearbox that doesn't require a mounting bracket, but just "floats off the front of the engine. PM me for more details!! whygoby
03-25-2020, 04:55 PM | #3 |
Can you be more specific.
03-25-2020, 04:57 PM | #4 |
03-25-2020, 05:05 PM | #5 |
03-25-2020, 05:37 PM | #6 |
Sorry...I blew that one! DD |
03-26-2020, 07:50 AM | #7 |
I should have been more specific on my specifying.
03-26-2020, 03:55 PM | #8 |
The reproduction Stewart Warner 674L tach drive unit doesn't require a mounting bracket, or inner flex drive link. The speedo cable that goes to the tachometer head holds the gearbox in place, so the unit just "floats". PM me for more details. Thanks, Doug
03-26-2020, 09:38 PM | #9 |
Is there something simple but not period correct for a tach? I would think some kind of magnet or sensor attached to the crank pulley could be read by a gauge on the dash with 12 volts... ??
03-27-2020, 01:01 AM | #10 |
On 12v you should be able to take the signal from the coil with just about any tach as gauge...or are we talking the worlds first dieselpowered flathead
03-28-2020, 05:39 PM | #11 |
Here is the new 674L tach drive gearbox that just "floats", and doesn't require a mounting bracket. PM me if you want more info. This gearbox shows up in the 1942 Stewart Warner master catalog.
03-28-2020, 08:55 PM | #12 | |
You got the diesel powered part right. No coil and the engine manufacturer no longer sells a tach drive for this model. 99 percent of the rest of the truck is still 47 ford. I can google it. I DO like that floating tach drive for my proper flathead powered vehicles.
03-29-2020, 03:10 PM | #13 | |
Lots of the big trucks has this. If you donīt have it open up the alternator install a wire to one of the stator windings where they attach to the rectifier and there you have you tachdrive signal. Last edited by flatheadmurre; 03-29-2020 at 03:17 PM. Reason: Added info for taking out tach signal |
