12-25-2019, 09:32 AM | #1 |
1937 Ford Speedo?
Hi all - can you please confirm which speedo this is ... 1937 Ford? Deluxe? Standard? Other?
Thank you! |
12-25-2019, 09:38 AM | #2 |
Re: 1937 Ford Speedo?
This is the same speedometer that came in my 1937 Deluxe business coupe. Hope that helps. Dave Collette
12-25-2019, 09:46 AM | #3 | |
Good morning Peter, and Merry Christmas! Your speedo is a '37 Standard. The picture below shows a '37 Deluxe, the difference being that the Deluxe has FOUR digits in the TRIP mileage window, whereas the Standard only has three digits. Dick D Below is an actual Deluxe dash. Deluxe has the two vertical chrome strips, plus the BANJO wheel. Note FOUR digits! The pic just below shows the actual dash in a '37 Standard. Note lack of vertical strips and THREE digit mileage window. Last edited by V8COOPMAN; 12-25-2019 at 11:15 AM. |
12-25-2019, 12:21 PM | #4 |
DD - Wow - amazing that Ford would go through the expense to have 2 near identical speedo's with the only difference being 1 digit on the trip portion!
Thanks for all the details. |
12-26-2019, 12:01 PM | #5 |
12-29-2019, 05:04 PM | #6 | |
Correct, there are no 37, 38 or 39 Ford Business Coupes. I know that there was 1940 Business Coupe (with jump seats), which is called by some -- but not Ford-- an "Opera Coupe." What years did Ford have an actual Business Coupe? |
12-29-2019, 08:28 PM | #7 |
I believe that there was a business coupe in '41. There was a coupe with jump seats along with the sedan coupe with the full back seat.
