05-04-2019, 02:13 PM | #21 | |
Re: 6V coil issue
Great world we live in these days... sigh Thanks for the heads up on the flame thrower coil. I’ll ya e to check that one out. And have one as a spare as well.
Isaiah B. 1928 all metal Tudor |
05-04-2019, 04:59 PM | #22 |
Re: 6V coil issue
I forgot to mention that the epoxy filled coil is the best bet for the model A . The epoxy coil can be mounted and run with the wire connections at the bottom . The oil filled coil is best mounted with the wire connections at the top or the coil can over heat and fail early . . This may not pertain to a performance coil . Others have mentioned coil problems with the coil being hot to the touch . Use of an oil filled coil on the model A can be problematic after a while if not mounted correctly .
05-04-2019, 09:11 PM | #23 |
Re: 6V coil issue
